weight for snow
The Supercrew isn't markedly heavier than a Scab. I promise, I had to work to get up in my driveway with the 2WD Screw when we got ice/snow a few weeks back. Granted I was on tires with 60K+ on them a the time, but tread doesn't help much on ice/sleet. The issue is that there is negligible weight over the rear axle in any truck, so an extra 300lbs sitting right on top of the driven wheels makes a ton of difference.
I don't doubt you one bit. I just mentally always saw it as a 2wd single cab thing. At the dealership I always see the Supercabs beds sitting a pinch taller than Supercrews, so granted they weigh in the same there is more weight on the rear of the Supercrew helping put weight to the axle.
You can shift on the fly, right?
The only reason I can think of is to save fuel.
But putting weight in the bed will hurt your fuel economy all winter.
Using 4WD occasionally will only hurt the fuel economy when you use it.
Adding weight will not help with braking.
Adding weight will not help with cornering.
The only thing that weight provides is traction when accelerating.
I have never found a problem with my truck in 4WD.
I would rather run around light all winter and turn on 4WD when I hit the snow.
Just my .02
Well now that he updated the original post that he's got 4WD, I don't know why you'd bother with the weight. The fuel mileage wouldn't suffer a ton, but I don't see it providing any advantage that turning the 4WD on wouldn't do. It's good to use the 4WD system frequently anyway to keep the parts moving.
