Storing the truck for two months..
Normally, when I tour with bands, I leave my truck for someone to drive at least weekly. This will not be the case this time. It'll be parked under a carport from dec 28th till feb 24th. I have a brand new motorcraft 750 cca battery, it'll have new oil and a filter in it. Has fresh coolant and new tires, along with a new alt and serp belt.
What steps should I take? Even though the battery is a month old, should I disconnect it?
My LT load c (50psi) tires flat spot just sitting over night in the cold. I have them set at 42psi. Jack stands aren't an option. Should I fill them to their max psi before letting it sit?
Anything else I should do? Full tank of gas, etc? I just don't want to have any problems when I start it up again in late feb and have to drive 350 miles home.
I know two months isn't that long and people do it all the time. But in the 5 years I've had the truck the longest it ever sat without someone starting it was a week and that's when my alternator failed.
Thanks guys!
Thanks guys!
My truck basically stays parked all winter because I'm not gonna expose it to New England Road Salt. I just start it up once a month & let it run for a good 20 mins to get the temp up all the way. The tires will flat spot but they return to normal after a drive. I replaced the original battery last summer with a Sears Di-Hard Platinum which will keep a charge for months on end so I'm not worried. I just fired up the truck this week after sitting for over a month in very cold temps. Fired right up no problemo. I also use a quality syn oil just for this reason. No worries you will be fine.
I'd add some fuel stabilizer to the gas, top it off, park it, disconnect the battery, and drive off. Two months really isn't that long. FWIW, disconnecting the battery eliminates any parasitic loss and guards against a fire should something malfunction. Makes it more difficult to steal too.
Two months isn't long at all. Thousands of cars sit on new or used car lots for that stretch and longer outdoors uncovered with no ill effects. Battery drain is probably your biggest concern and keeping the fuel tank full. Not a bad idea on the tires, but again 2 months really shouldn't affect anything if they are at max. A few mile drive will correct any flat spotting from sitting. Good idea on the moth ***** above, and if you have small chipmunks, mice, etc. it's not a bad idea to put a rag in the exhaust pipe.
No I don't disconnect it at all. Even when I had the original battery in. I put in a Sears Di-Hard Platinum last summer as the original was getting tired. This battery is AGM & Military Spec & holds a charge for months on end. If it rains & washes the roads free of salt I will take her for a nice highway run when the roads are dry for a charge. I'm the only guy around here who parks a 4WD truck in the winter! I won't let salt get to my truck! LOL
I fully agree. I try to do the same with mine even though the frame is pitted, there is no need to accelerate deterioration until I can handle it with POR-15. Not to mention a true gem of a real Harley Davidson edition! I'm happy to hear you keep it out of in-climate conditions and plan to keep it for a long time to come!
