Storing the truck for two months..
Old Dec 24, 2013 | 05:26 PM
risupercrewman's Avatar
Originally Posted by glc
For only 2 months, you don't even need to use Stabil, much less disconnect any fuel system components.
I totally agree! Two months is no problemo!
Old Dec 24, 2013 | 06:39 PM
Now, if I were storing it for 6 months, then I'd use Stabil and take some other preservation measures.
Old Dec 26, 2013 | 10:05 AM
SoonerTruck's Avatar
Agreed/ Stabil is a bit overkill on a 2-month hiatus. It won't hurt anything to use it, but it certainly isn't necessary.
Old Dec 26, 2013 | 12:45 PM
Labnerd's Avatar
The fuel stabilizer recommendation is not about the fuel separating or stratifying, it's about the hygroscopic properties of the ethanol in the gasoline. The stabilizer will keep the gas from sucking the humidity out of the air causing water to be in the gas when he comes back. You can't assume the guy has top tier gas or that he's in a dry climate.
Old Dec 26, 2013 | 02:52 PM
Thats true! I use a fuel stabilizer in my Harley Davidson Motorcycle when I put her asleep for the winter because of the 10% ethanol in the fuel nowadays!
