door ajar sensor
Old Feb 11, 2010 | 12:40 PM
azmidget91's Avatar
door ajar sensor
where is it? is it the little arm that is in the door jam? my door ajar light keeps coming on randomly.....really annoying
Old Feb 11, 2010 | 02:24 PM
mhockey9090's Avatar
Yeah its been happening to me the past 3 days but been too lazy to search or post anything haha. Would like to know also
Old Feb 11, 2010 | 02:45 PM
azmidget91's Avatar
i have searched and found nothing about the 04-08 trucks
Old Apr 16, 2011 | 02:32 AM
henkyjenky's Avatar
Anyone find anything?
Old Apr 16, 2011 | 11:28 AM
azmidget91's Avatar
nope, my truck now always thinks my passenger side door is closed, even when open...
Old Apr 16, 2011 | 04:29 PM
henkyjenky's Avatar
Bummer. Mine's going off and on rapidly while driving.
Old Apr 16, 2011 | 04:40 PM
bheemsoth's Avatar
If I recall, the sensor is located in the latch assembly. Ford vehicles have had problems with these for years, however the good news is that the solution is quick and cheap - just take some WD40 and spray it in the latch, then slam the door a couple of times. All should be good.
Old Apr 16, 2011 | 06:35 PM
City of Champs's Avatar
Yup, same thing happened on my '99 f150 just lube your door catch
Old Apr 16, 2011 | 07:10 PM
yes its part of the latch. lube it up and open/close it a couple times
Old Apr 19, 2011 | 12:21 PM
azmidget91's Avatar
i have sprayed a ton of wd40 in there and slammed the door a million times and still no worky, i think mine is actually bad
Old Apr 19, 2011 | 09:13 PM
put a latch on it then
Old Apr 20, 2011 | 12:39 AM
azmidget91's Avatar
but then it would have 2 latches on the passenger side
Old Apr 24, 2011 | 10:50 PM
niceasssupercrw's Avatar
You may not have a bad door switch. You may have a broken wire going to the security module causing the door adjar light to come on. Very common on these trucks.
Old Oct 5, 2011 | 01:28 PM
azmidget91's Avatar
Pulling this back up, Which module are you reffering to? is that the one on the back wall? or under the console? and where is the break usually at?
Old Oct 5, 2011 | 01:47 PM
Yes the security module in the BCM located behind the back of the rear seat.
