04 5.4L 3V Lean issues likely vacuum leaks
I have a 2004 F150 with a 5.4L 3V about 130K.
I've been fighting lean codes for a month now. Both banks. Replaced all O2 sensors and the MAF with motocraft parts.
I am now watching codes and outputs in real time with the Torque app.
Upstream O2 sensors seem to function normally (vary between .1 and .9) above 2K rpm.
Idle is very rough and eventually (3 minutes) stalls. Output voltage from both upstream O2 sensors drops to .01 on both sides at idle. If I punch the throttle at idle values jump up to .8 or .9 for a second then back to .01. I'm convinced O2 sensors are working properly. If I let it idle long enough it throws both P2195 and P2197 upstream O2 sensors stuck lean. I can drive it fifty miles (probably further) without a code but as soon as I let it idle for a few minutes it throws the codes. Always both of them.
I've researched a lot here and believe it must be:
A) a vacuum leak
B) a fuel delivery problem.
I have port blocked each hose/system from the intake and not found a vacuum leak or been able to improve the idle or o2 sensor readings.
Haven't changed the fuel filter yet but there is no fuel delivery problem under heavy load conditions so I assume there is no fuel delivery problem.
Where are the most likely vacuum leaks on this engine? Unfortunately it doesn't have the rotten elbow behind the manifold, apparently they changed that before my truck was manufactured.
Am I missing something about the fuel delivery system? I regularly clean the injectors. Is it likely that there are enough bad injectors to cause both banks to be lean?
Is three another sensor that may be the likely problem?
I appreciate your thoughts and advice.
A) a vacuum leak
Thanks for the responses, I've been away for a couple of days.
Codes are P2195 and P2197.
I've ruled out exhaust leaks. There are none.
Have tried starter fluid. No change in idle. Going to try it watching the O2 return voltages to see if they spike.
May be the intake manifold, trying not to think about it
In any event there is too much air and /or not enough fuel at idle.
Another session this weekend.....
