35"s on 3.73 gears? 2004 FX4
I have been running close to a 35 for over 2.5 years and have brand new ones in the garage ready to go on. With programmer i have no major power loss and tranny temp is not bad at all. I have tow/hauled with them a good bit too. Just be smart take off O/D when needed and i think you will be just fine.
Do you think this programmer is worth it?
http://www.pmtdiesel.com/diablo_spor...pogrammer.html
There's one on craigslist for $175.00 but I could try to negotiate depending on if its worth it.
The link did not work, but one word of advice i can give you is make sure the programmer has been disassociated with the original vehicle if its used. They are made to only actively work with one vehicle at a time, so if the owner did not do that its useless to you. I do not know a whole lot about the diablo products for F150s, but they are a reputable brand.
I have a 6 inch lift in mine and the previous owner had 33's on it. I purchased a SCT with custom tunes from VMP and was satisfied.
However, I just put on 35's and decided to bite the bullet and go with 4.56 gears last week and I can tell you the smoothness and driveability of the truck has increased dramatically! I will also shortly develop a thread after 3 gas fill ups to provide documentation of any MPG gain or loss.
Effective Gearing
Running 35's on our F150's with 3:73's gives you about a 3:55 effective ratio if I remember correctly. Which is a stock ratio and actually what my truck has. I run about 35's and I do feel its down on power but the tuner exhaust and intake make it livable. I will be re-gearing mine though cause it gives me a 3:31 effective ratio, not good for towing.
Well they certainly wouldn't suck, it will tow like it has 3:55's which is the highest gears these trucks came with from the factory, but I would think you would want lower.
