sluggish acceleration from a stop
Electronics cleaner ???? Careful - some of that stuff leaves a residue.
MAF = CRC MAF cleaner
TB = CRC TB cleaner.
Additionally, apart from unintentional damage, you may have introduced a leak upon reassembly.
That's what I was referring to here.
What did you find with the injectors? There IS a time factor here - this needs to be asddressed/fixed soonest, as every moment this persists is risking BOTH yer cats for an overrich condition.
MGD
MGD
you need to make note on which code came up first.....the rest can be echoes for that problem.....
I'm leaning toward a leaking injectors as others have stated....
but some other causes can be....
fouled or damaged maf
vacuum leak after the maf
pdf on trouble codes>>>http://mygtcs.com/mustang/documents/...scriptions.pdf
MGD
MGD
The electronics cleaner says it doesn't leave residue, and my injectors all seemed fine. I turned on the key and there was no leaking from any of them
I talked to a mechanic at a local truck shop this afternoon and he said that the only thing he can think of that could be causing the truck to run rich is the injectors. The spark plugs and fuel filter are less than 10,000 miles old, the air filter, maf sensor, and throttle body were cleaned 4 days ago. He said the only thing left after all that is the injectors and fuel pump, and it's not the fuel pump since it runs fine at speeds above 20mph. He suggested i look up my firing order and try swapping my bank 1 and 2 injectors (my engine codes say bank 1 and 2 are rich) with other ones and see if the bank 1 and 2 injectors cause the same problem in the new location. Does that sound worth while to try? And how long does it take to see if an injector is leaking? I just looked at each one for a few seconds and there was no obvious leak coming out of any
According to my programmer, my fuel rail pressure stays constant at 38-40 at idle, normal driving, and heavy acceleration (4500 rpms). I don't know if that's relevant to this problem or not, but I figured it couldn't hurt to let y'all know
pressure is fine.
I don't think it's injectors.
I'd go over the entire intake tract - remove everything again and examine - remember - that's the last stuff you physically touched. Still think it's a leak, or some sort of damage ( a MAF can look good to the naked eye and still have a pekkered TF) - but what do I know
'Eight-Eight' - any more insight, bud?
To confirm - still does this with stock OEM flash, right? Just checkin' - gettin' fergitful in me twilight years, y'know
Good luck.
MGD
Good luck.
MGD
pressure is fine.
Good luck.
MGD
Good luck.
MGD
After driving for an hour or so yesterday, p0172, p0175, p0581 did not come back up. P2196 and P2198 came back pretty soon after disconnecting my battery, but the other three did not come back. There's no difference in the acceleration
Don't give up on me. I think I'm narrowing it down. I got auto zone to look up my codes and this is what their computer said about the 4 rich codes. They all say possible MAF sensor failure. How can I tell if my MAF is bad? I've cleaned it twice with the CRC spray.
the k&n is basically dry. I barely oiled it then I cleaned the maf sensor about 700 miles after I cleaned the air filter. autozone has the maf for $115. it's duralast I believe. is it important to get a motorcraft one?
