sluggish acceleration from a stop
Old May 11, 2012 | 10:56 AM
Originally Posted by MossyOak3006
p0172, p0175, p0581, p2196, p2198. it's throwing all those codes right now. they're all related to running rich except p0581, that's something to do with cruise control. I don't know what's going on. the cruise works and it's driving normally on the interstate
you need to make note on which code came up first.....the rest can be echoes for that problem.....
I'm leaning toward a leaking injectors as others have stated....
but some other causes can be....
fouled or damaged maf
vacuum leak after the maf
pdf on trouble codes>>>http://mygtcs.com/mustang/documents/...scriptions.pdf
This is in the Articles and How To:
https://www.f150online.com/forums/ar...-new-post.html
Old May 11, 2012 | 11:19 AM
MossyOak3006's Avatar
You can pull a fuel rail with the injectors and place a cloth under it. Turn the key on and if one is leaking, you shoulde be able to spot it as gas will drip out. Easy to replace.
that sounds easier than changing the dang spark plugs. but the engine is my least knowledgable area of my truck so how take the fuel rail off?
Old May 11, 2012 | 12:03 PM
so with that extended warranty I should just take it to the dealership and let them tell me what's wrong?
There are two 8mm hold down bolts per side.....take them out and then pull up on the rail with a little rocking motion front to back as its pulled up....
Here's a really bad injector....
http://www.youtube.com/watch?v=-ARVK-ivf1g
Old May 11, 2012 | 12:05 PM
If you have it.....use the warranty
Old May 11, 2012 | 12:06 PM
His is an 06, don't think the warranty applies.
Old May 11, 2012 | 12:11 PM
Old May 11, 2012 | 12:28 PM
The injector letter won't apply but Mossy's extended warranty might....he'll have to read it....
Old May 11, 2012 | 12:30 PM
yes...take it in....see what the warranty will cover before they start to fix anything....
Old May 11, 2012 | 12:33 PM
Ok, I missed that the extended warranty was not the Ford injector warranty.
Old May 11, 2012 | 12:36 PM
what do you mean by my extended warranty? I didn't buy it at a dealership. I just hit 75,000 miles yesterday
Old May 11, 2012 | 01:10 PM
MGDfan's Avatar
Hmmm ...
I don't believe in coincidence, BUT - given it's reporting on BOTH banks, AND Mossy has touched the MAF AND the TB ( you did take it off to clean it, right?), I'm inclined to agree with Eighty-Eight's alternate hypothesis - an air/vacuum leak, or some sort of damage inadvertently caused by the R&R activity.
Very few reports of injector problems of that MY, but some early 06's may have the 'bad' injectors from the late '05 production run.
Worth checking for sure just to rule this out.
Old May 11, 2012 | 01:24 PM
Originally Posted by MGDfan
Hmmm ...
yes I took the throttle body off and cleaned it and took the maf out and sprayed it with the electronics cleaner spray that was recommended on here. I cleaned the k&n filter too, and I was careful to not over oil it so it wouldn't re-gunk the maf sensor
Old May 11, 2012 | 01:34 PM
oh so you don't have the extended warranty....you must have been refering to the injector warranty which is for the 2005 5.4 3v....
