Horrible fuel economy
Hey iam hoping someone can help me. My truck is getting 8.6 mpg ! Im not driving a hummer ive taken the truck to the dealer.they have no idea ive changed plugs bought a coil. Changed mass air. New fuel and air filter. Tires are at propper air pressure. No codes in the system. Its a 2007 mark lt so just nice looking f150 no one can figure it out iam thinking faulty pcm but fords computer says everything is fine. I have no leaks in the fuel system anyones input would be thankfull
Hey iam hoping someone can help me. My truck is getting 8.6 mpg ! Im not driving a hummer ive taken the truck to the dealer.they have no idea ive changed plugs bought a coil. Changed mass air. New fuel and air filter. Tires are at propper air pressure. No codes in the system. Its a 2007 mark lt so just nice looking f150 no one can figure it out iam thinking faulty pcm but fords computer says everything is fine. I have no leaks in the fuel system anyones input would be thankfull its a 5.4
I recently fixed my 12mpg highway problem. It was bad actuators on the front 4x4 hubs. Do this to check them:
Start your truck, in 2wd with truck running reach under each side and try to spin your half shafts by hand. If they wont turn then your hub actuators are bad causing the hubs to be locked all the time. After I replaced mine my highway mpg went from 13 up to 16. they are 122 each at Ford and both of mine were bad.
Thank you for the suggestions guys ill try looking at my hubs. Does the truck need to be on a hoist for that or just on the ground. I think my eshaust is ok but ill take a further look. I put it on my mac scan tool and o2 s were reading fine but the left rear was responding slower then the rest.should I replace it. You guys have been alot of help, thank you if I figure it out ill be sure to let you know
There are a couple of things you can do if you suspect the cats, try this link and see if it sheds some light on things.http://www.aa1car.com/library/converter.htm
I think that's the right one.
