Hid
Old Oct 19, 2011 | 07:07 PM
  #46
Originally Posted by jcrew2
Just bought me a set http://www.ebay.com/itm/ws/eBayISAPI...3A1123&vxp=mtr can't wait to get them installed. Watch out squirrel
Old Oct 19, 2011 | 09:41 PM
  #47
Raptor05121's Avatar
Hope yours doesnt end up the few I've seen. Driver "Bob" here was pulled over at a DOT inspection station on I-10 in North Florida (my jurisdiction). The officer told him he had an out headlight (PnP HIDs at their finest). So he tried playing with it. A minute later, 25,000V from an eBay chinese ballast making a short on piece of metal set something on fire. This was the end result:
I'm in this picture, but I'm not saying which one
Yes, that is a flammable sulfur resin in the trailer behind him. Luckily we got there in time. Driver was cited for equipment violation.
Have fun with that $65 kit
Old Oct 19, 2011 | 09:53 PM
  #48
jcrew2's Avatar
Will do, Thanks
Old Oct 20, 2011 | 08:45 AM
  #49
SoonerTruck's Avatar
I just hope you're not the guy in the yellow suit gettin' it on with the back of the truck.
Old Oct 20, 2011 | 10:44 AM
  #50
DanielWalker10's Avatar
Originally Posted by mSaLL150
Which version of the MiniH1 did you use? the Older versions had issues with the shield sticking, try their newest offering (v4 I believe). Also, the shroud must be epoxy'd on. The projector gets hot and those rings will loosen up causing your shrouds to fall off like yours did.
i did epoxy them the second time, i didnt the first time because i was under the impression they were sufficient. i had the first run of them i guess because they never did work right and i got tired of taking my headlights apart and having down time.
on a side note, i will be installing three $35 xentec PnP kits this weekend to add to the problem. lmao all for 90s model chevys, one is 5k, one is 12K, and the other kit has green bulbs.. haha
Old Oct 20, 2011 | 10:52 AM
  #51
Yep.....good quality china crap at its best......
Old Oct 20, 2011 | 10:54 AM
  #52
He's just checking his hose......
Old Oct 20, 2011 | 04:28 PM
  #53
sam1947's Avatar
Hey Raptor!..the 'jackwagon' here..keep watch of the papers for a 2007 F-150 burned-up like in the picture. Looking at the 'kit' the OP purchased, it looks like it is powered directly from the bulb pigtail. That being the case, the puny little stock wiring will be lucky to handle that load and will probably start blowing fuses (if he is lucky). Then he might put in a larger fuse and then we start to melt and burn the wiring harness up. We can only wait and see. (I truly hope not for his sake..I'm not a mean person). Not impressed with that set-up at all. I believe the 60 some dollars should have gone towards a better kit with a proper Harness/relay setup if he insists on going this route.
BTW '88' I think the squirrels will be safe at this point.
Old Oct 20, 2011 | 04:39 PM
  #54
  #55
http://www.youtube.com/watch?v=7nyo6RbggUI
Old Oct 20, 2011 | 07:16 PM
  #56
sam1947's Avatar
Originally Posted by 88racing
All for a $60 something P&P kit, what a waste. Don't take me wrong guys, but, we tried. I really do wish him luck, although, I think there will be troubles ahead.
Old Oct 21, 2011 | 10:09 AM
  #57
i used the same morimoto 35w ballast and harness from my retrofit with retro-solutions 35w 5k bi-xenon bulbs. my truck shouldn't catch on fire should it?
Old Oct 21, 2011 | 10:18 AM
  #58
jcrew2's Avatar
So a you found a ford truck that caught on fire on youtube. I saw a blazer 2 months ago on fire on I-40. This proves nothing, no where in the video or on youtube does it say casued by HID light kit. You FAIL, ok you don't like them, I do. I see plenty of trucks and cars on the road everyday with these kits, and the funny thing is all of them are moving not on fire. I'm using a relay to the battery for power, so there will not be any problems because they will draw the power from there.
Old Oct 21, 2011 | 11:12 AM
  #59
Look out for karma.........
Old Oct 21, 2011 | 11:13 AM
  #60
sam1947's Avatar
As long as you are using a wiring harness with the relays from the Batt. you are golden.
