Bed Bounce Solution?
Old Jan 7, 2011 | 09:12 AM
  #46
agood1's Avatar
You are right WINDSOR, I was looking at the wrong build date....$196 is much better, but still expensive, How do I find the Tasca guy?
Yes the toyota has a bad bounce when going over extreme terrain, but it is rock solid when on smooth road, something I cannot say for my Ford.
Old Jan 7, 2011 | 10:24 AM
  #47
Windsor's Avatar
Hit him up for a quote in this thread. Check out the link in tbear's #44 post is this thread. That link is likely the same part.
Old Jan 19, 2011 | 10:24 AM
  #48
agood1's Avatar
OK, I ordered this vibration dampner, but I sold my truck before it got delivered....so it is for sale. I'll take a loss and sell it for $100 + Shipping.
Email me at maxum25@gmail.com
Old Oct 23, 2014 | 09:43 PM
  #49
bighud33's Avatar
Originally Posted by agood1
My truck can be sitting still and and it will bounce. All you have to do is drop the tailgate or slam one of the doors. So it is not the tires.
I have this same issue, it drives me nuts.....
Old May 23, 2015 | 11:16 PM
  #50
rkneeshaw's Avatar
Anyone ever see this "instruction sheet" for the dampener installation? I can see where it is supposed to mount on the frame but not sure how I'm going to get the bolts through there without removing the bed.... or maybe that's the only way to do it?
Old Jun 2, 2015 | 12:55 PM
  #51
philip 87's Avatar
Out of curiosity, I looked under My 08 Mark LT and has it there as well.
Old Jun 3, 2015 | 09:53 AM
  #52
rkneeshaw's Avatar
Thanks for checking, do you have this bed shake on your truck at about 58 mph?
On my truck its enough to very obviously see it in the rear view and feel it shaking through my seat. Always between 55 and 60mph.
Old Jun 3, 2015 | 03:41 PM
  #53
philip 87's Avatar
Honestly, my truck is fine. I don't feel what you describe.
Old Jun 4, 2015 | 08:23 AM
  #54
philip 87's Avatar
You should bring truck back to dealer and have them check it out.
Old Jun 4, 2015 | 10:56 AM
  #55
rkneeshaw's Avatar
Philip, that is good to hear, very encouraging.
My truck is way out of warranty, and like others I've replaced shocks, balanced tires until I'm blue in the face, done alignments, etc and nothing fixes the bed bounce issue. Dealers turn people away telling them its just the nature of the truck. Ford did release a TSB in 2006 or 2007 that mentioned this "dampener" part, and started installing it on some of the later model trucks. This is supposed to address the harmonics issue causing the vibration. The fact you have the part installed, and you don't have this issue, gives hope.
I have the part and am going to install it. I just had to order a Torx Plus 50 socket to get my bed bolts out, because I believe the only way to install this weight is to lift the bed about 1" so i can get the bolts into position. I'll be sure to report back if it helps solve the issue.
Its a very very annoying problem to have.
Old Jun 4, 2015 | 08:48 PM
  #56
tbear853's Avatar
Guess you also got the rubber inserts and any sleeves that mount it?
Mine has the weight, and I know it has rubber mounting .... I assumed metal sleeves inside the rubber. I figured if there was a way to get the bolt in from below that the nut could have gone on top.
Curious is all ......... Good Luck!
Old Jun 15, 2015 | 10:23 PM
  #57
rkneeshaw's Avatar
Yep, the kit came with the weight, and rubber "bushings" already installed, and a pair of bolts and nuts. But no instructions.
I had to use torx plus 50 socket (TP50) to get my bed bolts out and lift the truck bed about a quarter inch, and then the dampener bolts slid into place. Got to say it was a pain in the butt to get the nuts on the bolts through those little holes in the frame. It would have been harder to get the bolts to go up from the bottom because you can't get a socket straight on from underneath, you have to work through the holes in the side of the frame rail.
But, I think worth it, because I drove about 20 miles on the truck and NO more bed bounce!
Old Jun 15, 2015 | 11:27 PM
  #58
tbear853's Avatar
I had to use torx plus 50 socket (TP50) ... etc ....
Well, that's the first confirmation I've read that the weight works.
I wondered what it was for when I saw mine in 2009 after bringing it home and "going over it" .... then this thread came up.
Old Jun 16, 2015 | 02:15 PM
  #59
k_h's Avatar
k_h
I added a rear sway bar on mine... when i go over any bumps now truck is a lot more solid and the bed doesn't dance anymore.
Old Jul 5, 2015 | 06:05 PM
  #60
rkneeshaw's Avatar
Just another update. i've driven the truck for a few weeks and this kit definitely made a big difference. Under the most perfect circumstances I can visually detect a slight bouncing, but if I wasn't looking for it I wouldn't notice it. This is a very clear improvement, my bed bounce used to be so bad it would shake the cab
