Does anyone else's truck do this??
I have a 2007 f150 sc fx4!! Only when the truck is in overdrive!! If I hit a pothole or bump in the road it downshifts and the rpms go up by 100 jst for a few seconds then it goes back!! I think if it was not for the change in sound of the exhaust I would never notice it!! You cant feel it!! Is this normal??
Thanks Jesse!!
Thanks Jesse!!
Wellsir - to prove this to you, just go pothole-hunting with the cruise control ON !!
You'll likely notice that the behaviour you describe does not occur !! And yes - it's not any cause fer concern !! Not to worry !!
Just be REAL careful-like !! !!
MGD v4.1 !!
on
Different gearing will produce different results also.
Same HEX calibrations?
Another thing that varies in these trucks is the calibration programs in the pcm's.
One calibration for one truck might have a more sensative setting for the pedal position sensor over the other one.
Yeah, its about the same as when some high school kids around town here drive around and rev it up while its still in drive. If your just cruising and tap the gas the rpms will raise but your TQ unlocks not causing you to surge forward. If the gas pedal remains held down then it will down shift and take off. I guess it can also be classified as the gas pedal lag.
on
Hello there sir !! How y'all doin' ??
MGD v4.1 !!
MGD v4.1 !!
When the CC is on the pedal response is put into a standby mode so you can still use it to speed up.
