TRUE leveling kit gain
So I'm wanting to lift the front of my 06 SCREW right at 2". Can I expect to get a true 2" out of a AS 2" kit or do you get less/more than the kit actually is? should I go with the 1 1/2" or 2 1"2 to get the 2" I'm wanting?
Please help me out here. Especially if you have my model truck and can tell me what you got out of what kit.
Thanks AGAIN!
Also, I'm not stuck on AS....
Thanks AGAIN!
Here is what I got out of my 2.5" kit. 05 XLT 5.4 supercab.
The last pic is with 285/70/17's
If you want an additional 2" and you're not planning on swapping tires, I'd go with a 2.0" leveling kit. A 1.5" may give you a little more than that, but it might not be a full 2.0".
Do you want the truck to sit level, nose down, or nose up?
- NCSU
Edited to add: I'm running the 2.0" AutoSpring leveling kit.
- NCSU
As far as I know, you are not going to get an exact 2" lift unless you get seriously OCD and engineer / build your own kit. The leveling kit lift heights are approximate, and honestly are usually rated a little low... For example, My Autospring 2.5" kit lifted me 2-5/8", yes only 1/8" difference, the next guy over might get 2-34" out of it. A lot of factors including weight, overall condition of the OE coils, etc... come into play.
Thanks for the info fellas!
- NCSU
- NCSU
If that makes since...
I am not a fan of the higher in the front look and often I've found sometimes the truck is level but it looks higher in the front...
