TRUE leveling kit gain
Old Nov 23, 2009 | 09:58 PM
Windsor's Avatar
Cuz, leveling your truck doesn't just involve lifting the front. You can also level by lowering the rear. Just another consideration that doesn't tie you into larger rubber to fill the void in the wheel well.
Old Nov 24, 2009 | 12:03 AM
Cuz's Avatar
Cuz
Yes Sir, I considered that but want the tougher more aggressive look of sitting a little higher.
Thanks for the heads up!
Old Nov 24, 2009 | 07:43 AM
NCSU_05_FX4's Avatar
Originally Posted by Cuz
I am more interested in the wheel well space above the tire. Wanting the space to be just about the same, maybe a little bit lower in the front BUT for sure not higher in the front.
If that makes since...
I am not a fan of the higher in the front look and often I've found sometimes the truck is level but it looks higher in the front...
I feel the same way. Do you do much towing? People who tow a lot tend to like the 1.5" kit because they don't get that "nose up" look when loaded up. If you don't tow often, I'd go with a 2.0" kit if I were you. Neither kit should affect towing capacity, so no worries there.
Are you planning on putting on larger tires down the road?
- NCSU
Old Nov 24, 2009 | 09:24 AM
Cuz's Avatar
Cuz
Might put larger tires on but no time soon. Just put new 285-70-17 on.
I tow a small camper about 2-3 times a year. I do though often have a couple hundred pounds of feed and what not in the bed...
Old Nov 25, 2009 | 03:41 PM
JTB 06KingRanch's Avatar
I have a 2006 King Ranch Screw. I just put a 2" AS level kit on last weekend and got it aligned yesterday. Before the kit, there was about 2.5" difference from front to back. With the 2" AS level kit on, it puts the front and back at the same height. I love the new look. I will post pics as soon as I can. I parked it for the winter now to help keep the salt off it. Its killing me to have it parked now. I will be putting lager tires on in the spring.
2006 KR Screw
Borla Exhaust
Volant Intake
Kenwood DVD Player and Nav.
Old Nov 25, 2009 | 05:51 PM
Cuz's Avatar
Cuz
Jtb, can u post a pic or two of the new look on this thread? Im ready!
Old Nov 27, 2009 | 11:54 AM
dbhost's Avatar
Not sure of the weights, but my truck is built for hunting trips... With 18 bags of feed corn for the deer feeders, my truck sits dead level with the 2.5" leveling kit.
From what I have notice though the 2004-2005 rear end sits higher than the 06-08.With the newer ones, I would probably go with a 1.5" spacer, 2" at most...
Old Nov 27, 2009 | 04:39 PM
Tylus's Avatar
excellent point
with a 04-05 truck you can run a 2.5" kit and it will sit with a very tiny rake
with a 06-08 truck you need to run a 2" kit. anything bigger and the truck is likely to sit nose high.
I had that problem with my 06. I installed a 2.5" and the front end was just a tiny smidge higher than the rear.
the AS 3" blocks for $125 gave the rear another 1" and would have corrected the nose high issue, but I sold the truck prior to installing.
I suggest you try a 2" kit. then if the nose is too high, grab the AS 3" rear blocks that will replace your OEM 1 5/8" (2") block for about 1" of extra rear hieght.
Old Nov 27, 2009 | 11:15 PM
Cuz's Avatar
Cuz
Originally Posted by Tylus
excellent point
INDENT,
You know after ALL the research I've done on this, and I've done a lot, I think I've come to this exact conclusion. I think I'm going to pickup the 2" and go from there...
Old Nov 27, 2009 | 11:26 PM
dave m's Avatar
that's just what I ordered up for my 07 FX4, ordered a Gryphon as well, off to get some tires ordered tomorrow. The truck's going to be alot different in a few weeks.
Old Nov 28, 2009 | 01:45 AM
2008_XL's Avatar
Yeah, as i recall, they used a 4 leaf pack on 04 and 05's and switched to the 3 leaf packs for 06+.
Old Nov 28, 2009 | 11:19 AM
YOMAN's Avatar
My truck 04 FX4, 295/70/17 Terra w/ 1.5 Autosprings. its perfect set up!
Its approx 1/4" nose lower than rear.
YOMAN!
Old Dec 2, 2009 | 11:00 AM
I posted some pictures of my 06 King Ranch with a 2" AS leveling kit. The difference was about 2.5" before the kit was installed. It sets level now.
Was unable to post it here, new at this site. I have not put bigger tires on it yet, I have it parked in the garage for the winter. Check out my pics.
Old Dec 2, 2009 | 11:02 AM
Old Dec 2, 2009 | 03:45 PM
Cuz's Avatar
Cuz
Nice truck!
