Want a Clevis
Old Dec 18, 2009 | 01:13 PM
  #31
BLUEBEAST06FX4's Avatar
Originally Posted by dilloncawthon
no they measure them really weird. i think by 2in.s they are measuring how thick the metal that the ring is made out of is, i guess that would explain why a 4in. one weighs over a hundred pounds.
oh ok i gotcha man hahaha
Old Dec 18, 2009 | 01:37 PM
  #32
Mr. eXtreme's Avatar
LOl... Yea that would. Mine's a 3/4 inch and it's still pretty heavy
Old Jan 27, 2010 | 01:55 AM
  #33
Drunkonjack's Avatar
Thanks for all the help ! I recently just purchase the shackle hitch from 4Wheelparts along with a 30ft 3in recovery strap rated at 30,000 pounds
I was wondering now what size D-ring would be best for attatching straps . The size thing is a bit confussing.
Old Jan 27, 2010 | 02:43 AM
  #34
freekyFX4's Avatar
Originally Posted by mdhawkin
Here is one, its a little more expensive than othere, but it looks to be built better:
http://www.4wheelers.com/cart.php?ta...product_id=997
Yalls stories are great, but it does suck when you try to help and find yourself in a bind.
That's the one I have on my truck.
Old Jan 27, 2010 | 08:50 AM
  #35
The size is the diameter of the clevis you need a properly rated one.
Old Jan 27, 2010 | 08:51 AM
  #36
What would be the best rated size then for general towing of vehecls out of the mud ?
  #37
Glen R's Avatar
I also have the Warn unit. It is the only one, forged in the US. The zinc coating leaves a little to be desired. I sprayed mine black with Krylon, before installing. Also seeing as the front hooks are closed, so I ordered a couple of shackles from SPA. They offer Americn made certified, OSHA approved, and imported clevis. I had to paint them as well, and added a set of urethane isolators from Daystar.
http://www.1st-chainsupply.com/attac...les/spa075.htm
Here are a few pictures of my setup.
Old Jan 27, 2010 | 08:54 AM
  #38
Glen R's Avatar
Most everything I have seen says at least 9500 lbs. Most units around that size are 9500, or 12500.
Old Feb 2, 2010 | 12:32 AM
  #39
freekyFX4's Avatar
How about this one?
200-ton clevis
Yes, it is larger than that wood pallet!
Old Feb 2, 2010 | 02:02 AM
  #40
08stx4x4's Avatar
How about this one?
200-ton clevis
Nice find. A shackle so big that it requires a 1/2ton truck just to move it around.
Old Feb 2, 2010 | 06:29 AM
  #41
How about this one?
200-ton clevis
LOL....I seen that one when I was looking and settled on a pair of 1 1/4'' Clevis. Rated at 12 1/2 ton. These should work for me.
Old Feb 2, 2010 | 09:39 AM
  #42
Glen R's Avatar
Just a rough estimate, based on 7.5 in 1018 stock, that thing should weigh in over 1200 lbs. This is a low estimate as forgings are generally denser, and thus heavier.
Old Feb 2, 2010 | 06:22 PM
  #43
greencrew's Avatar
I bought a light weight unit at Harbor Freight. Is this one tough enough? I can always use it around the yard on my garden tractor.
D-Ring Receiver Hitch
Old Feb 2, 2010 | 06:29 PM
  #44
Glen R's Avatar
Looks OK. I am extremely leery of Harbor Freight products, after having a pickle fork explode, while trying to remove the tie rods on my Nissan 4x4.
Old Feb 2, 2010 | 06:44 PM
  #45
_AC_'s Avatar
That's the one I have and it's built tough. I have the receiver one and two more hanging from my front bumper.
You just reposted yourself. Did you have deju vu? LOL
