Advice on putting together air horn system..
Old Mar 25, 2009 | 04:29 PM
FX4life's Avatar
What i have so far is two Grover 1510 air horns off of a Fire Engine, but I'm a little bit unsure what parts to run to achieve the best sound, and maximum performance from them. I know they run best between 120-150 psi. i was hoping to put together everything from scratch and try to save a bit of money by doing so.. So suggestions of where, what to buy and how to install are all welcome!
here is a link to a "complete setup" being sold for a single horn, hopefully i can do it for less than this guy wants. it comes to 388 shipped
Grover horn kit at Texas air horns
here is a quick vid of guy with the dual Grover 1510 setup
http://www.youtube.com/watch?v=akdsB-MZPm0
Thanks guys!
Old Mar 25, 2009 | 04:30 PM
bigdog87's Avatar
You must have a HELL of a job!
FreakyFx4 pretty much knows everything about Air horns and stuff.
Old Mar 25, 2009 | 06:03 PM
06 SANDSTONE's Avatar
I really think that set up is to small. 1 1/2 gals is not very much . I first had 2 1/2 gal. tank And It only lasted a couple of seconds. so what I did was add a 7 gal. tank to the 2 1/2 . Now i have a total of 9 1/2 . Now, That I have more volume . It makes my compressor run longer to fill up . I was glad I went with the 450c Viair compressor kit.http://www.viaircorp.com/10007.htmlIts a continuous duty compressor . Any more volume I think I'd have to run dual compressors. So be careful not to buy a small compressor . That one in that kit is small . Heres a pic . Hope this helps .
Old Mar 25, 2009 | 06:29 PM
nuclearthreat54's Avatar
Can you post pics of the 2.5 gallon tank mounting spot and the spot where you mounted the horn? And the button location, thanks!!
Old Mar 25, 2009 | 06:31 PM
efuehrin's Avatar
Do you have an air bubble laying around?
Here's a 10 gallon that I installed right behind my fuel tank.
I'm sure you have some extra room under there too. Then you would just need a compressor.
If ya put a big tank under there then you could use it to fix flats, run tools, whatever. Also I bough a electronic air valve off ebay for $50 that would work for ya. Mine is for a pneumatic can smasher I'm building.
Old Mar 25, 2009 | 06:58 PM
The tank is in the picture above . I do not have a button with a solonoid valve. I have a Graham White train horn valve . I mounted it where a clutch would go . I just push it with my foot to make it scream . I have a video on youtube in the link below . Its really not high quality . But you can see how it sounds .
Old Mar 25, 2009 | 07:35 PM
yetti96's Avatar
06 SANDSTONE,
Why did you cut up the carpet? Or is it like that, just padding...can't remember. I wish I could put my switch and gauge where, my big silly self would just rip that right off accidentally with my size 17 shoes.
efuehrin,
Do you have a lift? I cannot imagine a 10 gallon tank fitting there without hitting the axle.
Old Mar 25, 2009 | 07:41 PM
Thats how my under the dash looks, with that cheap padding. It looks really tacky but I dont know if its cut in the same pattern as his is.
Old Mar 25, 2009 | 08:32 PM
No,I didn't cut the carpet . Thats the way they built it .
Old Mar 25, 2009 | 08:52 PM
txarsoncop's Avatar
Train horns are the best, but a GOOD set of real truck horns are harn to beat. Those Grovers aren't a bad substitute when you can't afford Nathan's and such.
FX4life, our newest truck actually uses a solenoid valve even though there's a traditional chain hanging off of it. A mech valve may be cheaper but it's going to involve more tubing which can increase your leak liability. I agree with the advice to get the biggest tank you can fit and the highest CFM compressor you can afford. When/if you really lay on those horns they'll use a bunch of air.
Our tanks vary from the size of a 20lb propane tank and bigger and the pressure will drop if we hit the horns hard to get some moron out of our way, plus the compressors are huge.
Old Mar 26, 2009 | 02:11 AM
FX4life's Avatar
You guys all pretty much confirmed why I chose not to buy that kit I listed. Based on what yall have said if i could find a Big, cheap tank (10-15 gal maybe?), spend some money on the good compressor (probably a viair) get some 1/2 tubing and whatever fittings would be needed.
What i'm still a bit sketchy on is how i want to wire it up. What is going to be the best way to use these horns? wire them in a just use the stock horn push in the steering wheel (turning off stock horn by switch when i wanted the air horns), or go with a pedal/button elsewhere?
Old Mar 26, 2009 | 11:09 AM
The steering wheel set up with the switch is how i plan on getting mine wired up, i think its the best way IMO! Just make sure the switch has a light or something letting you know when the train horn is activated! That is a must in my set up, accidently tapping the train horn in the wrong situation is bad beans
Old Mar 26, 2009 | 11:15 AM
efuehrin's Avatar
Originally Posted by yetti96
efuehrin,
9 inches. The axle isn't even close to the tank. It just looks that way.
Old Mar 26, 2009 | 11:18 AM
abercrfootball's Avatar
Here is my setup...
Old Mar 26, 2009 | 11:21 AM
Tank is a 3 gallon, compressor is a Viair 380c and I also have a 150psi pressure switch
