Edge install...and alittle insight..
Old Mar 9, 2009 | 08:43 PM
  #91
kingofkings's Avatar
I don't see how the programmer could void the entire bumper to bumper warrenty....I would be interested to see how a programmer caused my emblems to peel. LOL.
I would believe if you took it in for a tranny or engine issue with a programmer installed that they may speak up and say something. I will probaly pull mine in the morning before going to get this emblem situation taken care of.
Old Mar 9, 2009 | 08:49 PM
  #92
Originally Posted by arrabil
Yeah, but I'm not changing the stock tune under any circumstances so I don't know how much of it I'll feel. Tires sizes, gear ratios, gauges, ODBII scanner features, shift points, shift firmness, and 0-60 timings, those features I will use. And if the shift firmness actually works, that would save me from buying a new valve body from Troyer.
Interestingly, here is what Troyer says about their valve body:
If you are using a performance chip or programmer, you may (or may not) want to back down the light-throttle shift firmness levels (if you are using our Troyer Performance custom tuning, we can easily take care of this for you, just give us a call at (540) 965-7126), depending on your individual preference for shift firmness.
So they are implying the programmers change part throttle shifts and not WOT ones. Whether that is correct, a misprint, or only applicable to other programmers is anyone's guess.
WOT shifts are always supposed to be firm so what they're saying makes perfect sense to me. At the same time your guy's actual experience cannot be discounted either. So I'll be finding out for myself since I'm a universal cynic.
Are you saying that you are goingto run the stock tune only, with the Edge installed?
Old Mar 9, 2009 | 08:52 PM
  #93
dlenkewich's Avatar
I broke down, bought an edge. Only played with level one custom settings.
Next time I go out I'm changing to level 2.
Alright, I saw good points for shift firmness, etc. Has anyone played with WOT Fueling or the other nifty settings?
I want to play around, but I'm afriad I may harm the truck if im not sure of what I'm doing.
Old Mar 9, 2009 | 08:54 PM
  #94
last5oh_302's Avatar
That's what I take from it.
arrabil, you probably would've been better off saving a few bucks with a Scanguage.
  #95
sml175's Avatar
Saw the postings by Ford. There is some kind of minute clause that allows the entire b2b warranty be voided. There had to be 6 people who joined in this conversation at the dealer today. All of us almost when we saw all the voided claims and warranties due to programming beyond the dealer.
Last edited by Bluejay; Mar 9, 2009 at 08:57 PM. Reason: Do not circumvent the language filter, please.
Old Mar 9, 2009 | 08:55 PM
  #96
There is a lot to be gained but there is no such thing as a free lunch.
If more power and more fuel economy could be had as easily as reprogramming the computer, believe me that Ford, Chevy, and Kia too would be all over it. So there must be a tradeoff. It could be as simple as gas quality concerns or it could be as simple as trading low-end torque for high-end horsepower. But it also could be as complicated as lowering the life-span of the fuel pump and injectors to something with the piston rings.
I plan on having this F-150 for the next 15 years and only expect to have trouble with the transmission. The rest of it can get figured out by the people you guys sell your trucks to.
I disagree with you. Ford left a lot on the table because most people like to sluchy smooth shifts and they like smoothness as opposed to pep. The intentionally detuned it leaving the aftermarket tuners lots of safe room for improvements. One example, it's a known fact that firm shifts allow trannys to last longer, yet they build the slippage into it from the factory because that is what the masses want.
I plan on keeping my truck for a LONG time. If I had any feeling whatsoever that the tune I am running was harming it, I would not do it. I expect to get 300,000 out of it. I had thoughts of buying a 2009 until I saw them and decided to just keep this one. I love this truck, and I love the tune from PHP that makes it so fun to drive.
Old Mar 9, 2009 | 08:59 PM
  #97
If that is the case, all you can do is use the monitor. You will not be able to change anything, not even the tire size. You must be on Level 1, 2 or 3 to change anything in the PCM.
Old Mar 9, 2009 | 09:00 PM
  #98
I guess it depends on the dealer.
Simple rule of thumb; put truck back to stock and remove Edge before getting there.
Old Mar 9, 2009 | 09:06 PM
  #99
sml175's Avatar
Exactly what I thought. Until the tech showed us how the computer actually records changes and access to the system. Sort of like the black box recorders. He also said they could tell because even though you remove any settings and revert back to "default", the programmer actually has to leave some sort of marker to reboot at that certain sector. This is true if you have a computer and everytime you reboot, it always goes back to the same place, kinda like cookies he said. Then he showed us his OWN Diablo and said that it also leaves a marker. If Ford sees the changes, the warranty will be voided, no ifs, no buts. they even had a book with case-law in it based on the people who tried to sue Ford. Ford won each time. Scary huh? This dealer is in NJ.
Old Mar 9, 2009 | 09:14 PM
  #100
I suppose if a dealer is specifically looking for it, they could find it. I'm not concerned.
I've yet to read about anyone having their PCM searched for other access, and having their warranty made void because of it.
I have a good dealership I deal with. I would even be comfortable enough to ask about this. I'll be taking the Focus there tomorrow. If I remember, I'll ask the service manager.
Old Mar 9, 2009 | 09:15 PM
  #101
sml175's Avatar
Please do. I hope these guys were the only ones because I was going to order and Edge next week.
Old Mar 9, 2009 | 09:17 PM
  #102
bjp207's Avatar
you need to find a different dealer...unless they can prove that the modification caused the problem they cant void the entire warranty...the tuner has no influence on brakes, ball joints, hvac system, etc
Old Mar 9, 2009 | 09:22 PM
  #103
sml175's Avatar
Yes, they can, and YES they did.
Old Mar 9, 2009 | 09:23 PM
  #104
sml175's Avatar
I am not getting into a pissing match here. Just telling you what I saw and read. And as a retired PO I hope I can still understand legal jargon. Look into case law concerning this issue, see what you find.
Old Mar 9, 2009 | 09:24 PM
  #105
arrabil's Avatar
Ha! Thats an easy one. The programmer increased your 0-60 times and hence put more strain on the emblem glue which it wasn't designed to take.
Is a scanguage cheaper than $200?
I'm going to run Transmission Only. That allows me to change the other parameters, right?
But this is the only example I can think of and is why I'm interested in correcting only this. What other known things have been given a mechanically poor solution because the public won't accept the alternative?
Bluejay, the proof is in the pudding. When Ford advertises 21MPG in the '09 F150 what is different about it from the other models? 3.05 gears is what. If they could achieve 21MPG without neutering it, why would they choose anything else? The MPG game is the current hot-ticket item in full-size trucks. And yet none of the manufacturers tune the crap out of their motors to get a leg up? Doesn't make sense unless they are already tuned as well as possible under the given requirements.
And again, Ford's tune is for 83 Octane. You are completely right that there is a lot of wiggle room when you re-tune for 87 or 91 Octane. But then when you take a trip to the Rockies you either need to put it back to stock or even worse, make the knock sensors work overtime. Ford cannot do something like that and I don't want that hassle.
Finally, if Ford wanted to make anything easy on the aftermarket, they wouldn't be voiding people's warranties. Instead they would be licensing "official" tuners and making money off them.
And the principle of no free lunch isn't just a saying. Its a well known that larger exhausts and freer-flowing intakes give you more high-end horsepower at the expense of low-end torque. Ford makes the compromise where they see it as right. That leaves you to readjust, sure, but I happen to agree with where they put it: max torque at the lowest possible RPM while keeping the peak HP over 300 for marketing reasons. Its not like I need this thing to go 145MPH.
You and I can disagree, and I can't say I really know anything, but I think the manufacturer's own actions prove the point to me.
