HID Lights Pointing them Down
Old Nov 12, 2008 | 02:27 AM
outlawz28's Avatar
Registered User
I have installed HID lights into my 2005 F-150 which has a leveling kit. I have blinded people more than few times. I was wondering is there anything I can do to point the HID lights a little more down?
Old Nov 12, 2008 | 07:57 AM
ford2004F150's Avatar
A-hole!
J/K
Buy some hella headlight housings - stop blinding people!
Old Nov 12, 2008 | 09:48 AM
Twist the lower headlamp angling ***** down a bit to angle the headlamps down. Ford offers a tool for it, but working man hands can do it no problem.
Old Nov 12, 2008 | 08:08 PM
outlawz28's Avatar
Registered User
what are the angling ***** ?
Old Nov 12, 2008 | 08:31 PM
hippo's Avatar
there is a small threaded bolt w/ hex end on the top rear of each headlight. if you are looking at the back of the headlight turn this clockwise (with plyers) to adjust your headlights beam downward...hope that helps ya
Old Nov 13, 2008 | 12:24 AM
BlackandProud's Avatar
i live in a rural area and all i did was drop them all the way to the floor... no problems and still bright as hell
Old Nov 13, 2008 | 09:40 AM
YOMAN's Avatar
Originally Posted by ford2004F150
A-hole!
J/K
true true..I have Hella headlight and it sure helps less glare but i still adjusted headlight a little lower to ground. it helps.
YOMAN!
Old Nov 13, 2008 | 09:42 AM
Krohbar's Avatar
Pliers????
Get a socket... do it right.
Old Nov 13, 2008 | 10:52 AM
Rockpick's Avatar
Moderator &
Originally Posted by Krohbar
Pliers????
Better yet...
get a Lisle 14540. http://www.lislecorp.com/tool_detail.cfm?detail=96
Old Nov 13, 2008 | 04:12 PM
Krohbar's Avatar
Originally Posted by Rockpick
Or that...
Old Nov 13, 2008 | 04:19 PM
Impact9's Avatar
put this on the list of things to know before you install HID headlights.
Next week... how to inflate a tire.
Old Nov 13, 2008 | 08:12 PM
hippo's Avatar
Pliers????
thanks for the spellcheck! and unless you plan on taking off the headlights, a socket will not fit behind this bolt. either PLIERS, or that specialty tool
