Window Regulators!!
Old Sep 27, 2008 | 09:08 PM
  #46
mkosu04's Avatar
MTpint - when you put in the new regulators do you make sure the glass is back all the way??? Someone on here said something about it and after I adjusted mine it ran much smoother.
I'm thinking there must be something that is causing yours to fail so much... it just doesn't make sense that all your replacement parts are going bad.
You don't lean on your buttons while driving, do you? Like if you were pushing the UP button while driving... that might trash the regulators quicker?
anyway... sorry about your bad luck. Hopefully this one lasts awhile
Old Sep 27, 2008 | 11:06 PM
  #47
edgespeeder06's Avatar
question: is this covered under warranty? mine just went today on the way home for the passenger window
Old Sep 27, 2008 | 11:12 PM
  #48
If you're truck is still under warranty I'd say yes.
Old Sep 27, 2008 | 11:14 PM
  #49
mkosu04's Avatar
that depends... is your truck under warranty???
You didn't tell us your year or mileage.
If your truck is still under the full warranty, then yes it is covered.
If not, it will cost you around $130 and a few hours of your time.
Old Sep 27, 2008 | 11:26 PM
  #50
ah okay good, yes it has extended warranty until late next fall, and 43k
Old Sep 28, 2008 | 11:08 AM
  #51
MTpint's Avatar
I have only done one the last one all others where under warranty. I believe its the heat is killing them. My truck is black and is pretty much in the sun all day
Old Sep 28, 2008 | 12:26 PM
  #52
Mine is black too. I think you're right about the heat. I purposefully don't use my windows as much because of the knows failures, and have had two so far.
You never know when it's going to fail, no warning whatsoever, at least in my cases. I got lucky with my driver's door, I actually grabbed the window before it fell in the door and was able to duct tape it up so I could still go to work with my window up. My passenger window regulator went BOOM and the window instantly fell in the door. Sounded like a gunshot.
Old Sep 29, 2008 | 12:13 PM
  #53
mkosu04's Avatar
ah... that could be... Someone (AZmidget I think?) posted that he fixed his and it was a plastic piece that had failed. The heat could weaken the plastic.
bummer
Old Sep 29, 2008 | 06:35 PM
  #54
dkstone05's Avatar
Something told me I should not have posted in this thread below. My passenger side window switch is starting to go on the fritz. The switch on the passenger side door will roll the window down but not up.....At least it's not the regular
Old Jan 15, 2010 | 01:26 AM
  #55
4 da boat's Avatar
good job guys this is going to be my project for the weekend....1st window 04 75000 mi. thanks
Old Mar 14, 2011 | 03:21 PM
  #56
mtbinva's Avatar
OK, I have a new twist to add to this. I have an 05 FX4 4 door with sunroof and electric back window. ALL of the windows stopped working. ALL of them. I replaced the fuse, no go. The sunroof and the rear window still work. None of the windows will work from the driver side console or any of the individual windows at their respective switches.
Any thoughts as to where I can even begin to troubleshoot?
Old Mar 15, 2011 | 09:22 AM
  #57
lenore's Avatar
Hey guys, I have replaced the drivers and passengers regulators on my 2005. Ordered the parts from a dealer up in Washington...lot cheaper.. Yes the plastic supports break...but what I have found is that they put no lube on the rails where the plastic slides...too much friction...I put lubriplate grease on the rails before I finish the job. the window glides so much more freely.
the plastic did not look brittle. Note Ford has made no improvements to the regulator assembly. the replacements are identical to the failed ones.
Old Jul 26, 2012 | 05:40 PM
  #58
lenore's Avatar
ok installed the Dorman brand window regulator...looks to be excellent quality....went in easy and works great...took the last remaining door apart and lube rails.....
Old Jul 29, 2012 | 09:47 PM
  #59
Fireman1291's Avatar
Link to this regulator assembly lol? My front and rear passenger regs failed.
