Rear Block Lift..ARGGHHHH!!!!!!!
Old Jul 22, 2008 | 04:34 PM
diggman08's Avatar
Exclamation Rear Block Lift..ARGGHHHH!!!!!!!
ok so on my True Blue metallic Supercrew fx4.. i have the 2.5" autospring kit, and the Rear AutoSpring 3"block ( replaced my stocks)
im just not happy with the appearance..
basically stock block (1 5/8") sits to low in back
Autospring block (3") sits just a tad to high in rear for my liking,,, i just cant warm up to it..
so does any one know where i can get say a 2 1/4" block at or made??
i think it would sit perfect with that size.. i mean it should its right in the middle of the other 2 options ..
thanks
Mike
Old Jul 22, 2008 | 04:56 PM
Impact9's Avatar
oh wait you want a smaller block than the 3" AS, hmmm ok might be easier to order a add a leaf kit or go to a local spring shop and get a leaf made.
Old Jul 22, 2008 | 05:08 PM
scott1981's Avatar
http://www.4wheelparts.com/Lift-Kits...5539&t_pl=3902
they sell a 2.5" block that is almost exactly what you want. Add-a-leafs are a pain to install and make for a rougher ride. I would just replace the block if I were you
Old Jul 22, 2008 | 05:09 PM
diggman08's Avatar
yeah Auto spring said they could fabricate me a 1" helper leaf..that will slide right in.. use it along with stock blocks.. would that sit lower than just a 3" block??
i just figured it would be easier just to get a smaller block... plus i like the ride quality with the softness of the stock springs
has anyone done this??
Old Jul 22, 2008 | 05:11 PM
diggman08's Avatar
thanks scott... do you think that will make much a difference though... i really want to get something closer to the 2" side.. to make any visual impact.. but ill check out that 2.5 too
Old Jul 22, 2008 | 05:13 PM
scott1981's Avatar
People have removed the blocks to level the truck and installed larger blocks for lifting. So many people have used blocks to do what your doing.
Its the best bet with the least amount of work IMO.
Old Jul 22, 2008 | 05:15 PM
diggman08's Avatar
welll so i just looked at your link.. and they also make the 2" and everyother size. EXECPT THE ONE I WANT.... hmm...
what do yall think?? 2" block or 2.5" block im about 60% for the 2" 40% for the 2.5"...lol... i just think a 2.25 would be PERFECT..
also do those Super lift blocks come with the round Nub that goes into the leaf spring like the Autopring block and stock block???
mSaLL150's Avatar
put your stock blocks back on, replace 2.5" leveling kit with a 2" leveling kit. DONE.
Old Jul 22, 2008 | 05:16 PM
scott1981's Avatar
They sell 2" also, that might be better for you. I think having a 2.25" block custom made would be too costly for just the extra quarter inch. In my hasty google search I was unable to turn up any 2.25" blocks for sale
Old Jul 22, 2008 | 05:17 PM
diggman08's Avatar
i agree.. it took them about 45min. to put my AS 3" blocks in.. and the ride is Excellent..
scott1981's Avatar
Yeah they have to have that as it holds everything together. I believe they have 2 sizes though so double check to see what size "round nub" ya need
Old Jul 22, 2008 | 05:20 PM
diggman08's Avatar
on this truck i have 35x12x50's with 00000 rub at full lock( but its very close).... so i think down sizing my leveling front kit is out of the question.
Old Jul 22, 2008 | 05:25 PM
scott1981's Avatar
Yeah 35's dont leave any room to come down, I think your headed in the right direction
Old Jul 22, 2008 | 05:30 PM
diggman08's Avatar
any pro's wanna chime in on that pin size on the 2004 f150 rear Block??
the super lift sizes are in the above link... thankss
can i just use my Autospring U-bolts??
still undecisive 2 or 2.5" i hate to get a set then decide i wanted the other size..lol... then ill be stuck with 4 sets of rear blockss.. i know i nkow... im a perfectionist though
Old Jul 22, 2008 | 06:07 PM
Mr. eXtreme's Avatar
I just got my AS 2.5 spacers and 3 rear block Saturday!!
But I do alot of towing so I'd rather it sit high at rest and level towing!
IMO...
I would go with a 2.5 inch block, I'd rather the rear sit a lil high then to low.
