Rear Block Lift..ARGGHHHH!!!!!!!
Old Jul 24, 2008 | 11:35 PM
  #31
FoMoCoFan17's Avatar
Originally Posted by diggman08
Bump!
For what?
You have the options in front of you. Now it's time to make a decision.
Like I said earlier, the stock block with shims sounds like your best bet to get the exact height you want. (Crap, no beers)
Old Jul 24, 2008 | 11:56 PM
  #32
07fx4silver's Avatar
Originally Posted by FoMoCoFan17
For what?
X2, I would use the stock blocks and get the pro comp shim kit
Old Jul 26, 2008 | 01:52 PM
  #33
diggman08's Avatar
ok thanks guys.. i was just bumping it.. to see if anyone new if those Superlift blocks woould work.. but ill look into those shim kits.. where do i find them at??
07fx4 you truck looks sweet with the new mods... i was thinking of getting those exact rims, but in the Knight Crhome color..
Old Jul 26, 2008 | 03:44 PM
  #34
Thanks, the knight chrome wheels look good. Part number for the shim kit is EXP52700. 4 wheel parts has it for 26-27 dollars.
Old Jul 26, 2008 | 06:21 PM
  #35
diggman08's Avatar
thanks i checked em out... is this the right thing i need?? it says DRIVELINE ALIGNMENT SHIM KIT.. what exactly is that and what does it do.... my drive shaft is fine the way it is
Old Jul 26, 2008 | 07:23 PM
  #36
Yes, it's what you need. They install on top of your stock blocks and you can gain 1/4", 1/2", 3/4" or up to 1" depending how many shims you use (8-1/4" shims in a kit). 4 Wheel Parts calls it a driveline alignment shim kit but they are just FORD REAR END SHIMS straight literature from pro comp's web site. I ordered mine from 4 Wheel Parts so ignore whatever title they call it, they work just fine
Old Jul 26, 2008 | 08:28 PM
  #37
diggman08's Avatar
ok thanks.. thats what i needed to know.. how many shims did you use for yours??? i thought you had the 3" AS block with the 2.5 up front??
Old Jul 26, 2008 | 08:48 PM
  #38
No, I used to, but I've had a pro comp 6" lift for about 2 months now. I used all 8 (4 per side) with my pro comp lift
Old Aug 8, 2008 | 04:19 PM
  #39
BigMan's Avatar
so what happened with this. I am looking to raise my rear end up also. I have the 2.5" AS kit and I want the back higher. The easy way is to buy the AS rear block but its ovr $100. Id rather get the ones from 4wheel parts for $30-$40 down the street from my house.
Old Aug 8, 2008 | 04:48 PM
  #40
Oxlander's Avatar
Are you 4wd or 2wd? With 4wd the shim kit is the way to go. I'd say, depending on what you haul/tow, that 3 shims per side (.75") would give you a nice rake.
With 2wd you should get a block or an AAL.
Old Aug 8, 2008 | 04:49 PM
  #41
BigMan's Avatar
I got an FX4
Old Aug 12, 2008 | 11:25 PM
  #42
johnfields20's Avatar
When I looked on the 4wheelparts website for the shims it just doenst have one kit it has like different ones maybe someone can point me in the right direction.
Old Aug 12, 2008 | 11:38 PM
  #43
freekyFX4's Avatar
Originally Posted by scott1981
http://www.4wheelparts.com/Lift-Kits...5539&t_pl=3902
they sell a 2.5" block that is almost exactly what you want. Add-a-leafs are a pain to install and make for a rougher ride. I would just replace the block if I were you
Add-a-leafs are very difficult to install on these trucks because of the size of the leaf spring eye bolts and the location of the exhaust and gas tank. I do prefer the stiffer ride with the add-a-leaf though.
Old Aug 12, 2008 | 11:43 PM
  #44
Just give them a call and they should be able to hook you up. Part number is 52700
Old Aug 16, 2008 | 11:18 PM
  #45
shocker11's Avatar
I am 2wd and want 2" in the rear what should I do? 1.5" as block and 1/2" spacer but what spacer? 2degree shim 4degree whats that
