I fixed my poor A/C performance
Old Jun 27, 2008 | 03:44 PM
  #106
Shane1's Avatar
Did this mod this morning. Heres the parts I used: Napa 3/4" Shut - off valve Part#660-1413, 4"s of 3/4" heater hose & three worm clamps. I'm headed out right now to get some temp reading.
[IMG][/IMG]
Old Jun 27, 2008 | 04:28 PM
  #107
projetmech's Avatar
looks good but is it restrictive. if it is the it will affect the heat in the winter.
Old Jun 27, 2008 | 07:31 PM
  #108
bamorris2's Avatar
[IMG][/IMG]
Come on already! It's been 4 hours, and still no report on the temp reading??
Old Jun 27, 2008 | 08:41 PM
  #109
JBMX928's Avatar
Graphics Contributor
Originally Posted by azmidget91
thats because your a wanna be mexican
owned!
Old Jun 27, 2008 | 09:48 PM
  #110
Shane1's Avatar
Did my temp testing. I got no real results. With the valve open or closed I get the same readings inside the vent.
On MAX A/C fan speed 4 sitting temp is 56* freeway temp is 47*.
On regular A/C fan speed 4 sitting temp is 63* freeway temp is 49*.
Edit Edit Edit Edit!!!!!!
Allright not happy with the results above so I checked my thermometer and clamped the hose off to make sure my valve isn't leaking.
The thermometer is working, got it down to 32* in the freezer.
With the hose clamped off I got down to 44* on the freeway on MAX A/C fan on 4. BUT the sun had just set the temp outside was still 104*.
I'm not satisfied with the results yet. More testing this weekend.
[IMG][/IMG]
[IMG][/IMG]
Old Jun 28, 2008 | 02:19 AM
  #111
Shane1's Avatar
Blueovalfitter was right, The valve I got from Napa is doing it's job...back to the hardware store!
Old Jun 28, 2008 | 02:45 AM
  #112
bamorris2's Avatar
Huh? If it's doing it's job, then why are you going back to the store??
Old Jun 28, 2008 | 03:06 AM
  #113
Shane1's Avatar
Woops I meant isn't doing it's job! Typo!
Old Jun 28, 2008 | 09:36 AM
  #114
JesseRohr's Avatar
If this mod wasn't so ugly, I would have done it already.
Old Jun 28, 2008 | 12:51 PM
  #115
Walter150's Avatar
Cutoff Valve
Thanks to all for mod and suggestions - took longer to make make up my mind on this one than to install. Here's a link to my Misc directory With a picture:
https://www.f150online.com/galleries....cfm?num=16712
Old Jun 28, 2008 | 01:54 PM
  #116
Shane1's Avatar
I'm going back to stock configuration today. Until I can find the smallest ball valve possible. Walter150 where did you get yours? It looks pretty short compared to the OP's and others!
Old Jun 28, 2008 | 02:07 PM
  #117
Walter150's Avatar
Lowe's
Per je3169's post and link, got it at Lowe's. I also followed someone's suggestion to not cut the existing hose and add a short section of new hose.
Old Jun 28, 2008 | 02:58 PM
  #118
Shane1's Avatar
Have you noticed a difference?
Old Jun 28, 2008 | 03:22 PM
  #119
Walter150's Avatar
Yes, but
I haven't driven it yet. I let it idle up to temp with the heater on - plenty hot. Shut the valve off, ran fan, cooled right down. Ran A/C at idle in garage (no outside air flow) and seems much cooler at the vent. Sorry, no thermometer.
Old Jun 28, 2008 | 03:36 PM
  #120
BlueOvalFitter's Avatar
Thumbs up
I have been buisier then a one wing dove in a hurricane.....
Monday,i'll take pics of some of the valves I recommend for this mod.
BTW,I am in the process,at work,of piping 539 VAV boxes.That is 539 times 2 valve packages that have to be made up!
