I fixed my poor A/C performance
Go to Autozone and get PN 5968, Ready Aire Heater Control Valve (2 port) or PN 5954 Ready Aire Heater Control Valve (4 port).
You'll also need a vacuum line "tee" to splice into your recirculate air control valve. Run the vacuum from the recirc valve to your heater control valve. This will shut off the heat to the heater core when the AC is on MAX/Recirc.
Edit: FWIW,
The A/C's "radiator" in front of the engine radiator is called a condenser and the "cold" part of the AC in the cab is called the evaporator. They are in no way connected to the radiator and/or heater core.
Edit: FWIW,
PRV-Pressure Reducing Valve-used to lower pressure to a certain psi from an incoming water source which is at a higher psi then desired.
We use these valves in the chill water systems we install in industrial and commercial a/c systems.
Okay...one more time guys:
What is the size of the heater hose? As I look at it, it appears to be 3/4" OD. The crux of my earlier posts is really asking what is the ID (inside diameter) of the heater hose. I would like to know this so that I can get the correct diameter nipples to insert in the hose ends once I cut them and I can't drive the truck. So far, in this thread there are conflicting reports as to the diameters of parts that were used. We have:
1. Spoongooner = 1/2 ball valve & 1/2" nipple (not to mention CAT valve?)
2. Yamaha YZ 250 = 3/4" ball valve (didn't mention size of nipple on valve)
3. chris116c = 1/4" ball valve & 1/4" nipple
So the members are posting a 1/2" difference in diameters of ball valve openings and in the diameter of the nipple that is inserted in to the input heater hose. I don't believe that OEM hoses to the heater core vary by that much, so there must be some jerry-rigging, weirdly crimped or totally stretched heater hoses associated with these mods. Can anyone clarify this for me? Thanks a bunch guys!
I first bought a 1/2" nipple and ball valve that was the diameter of my heater hose. So I went back to HD and bought a 3/8" nipple and ball valve. The 1/4" didnt quite fit well. The 3/8" fit inside the hose perfectly, throw some hose clams on there and presto. Sorry for the other post it is 3/8" that worked best for me.
Thanks Chris. Spoongooner must have forced the 1/2" in to his hose ends...perhaps stretching the heater hose a bit. Tonight I'll stop at HD and get the 3/8" ball valve & nipp's as per your note and some hose clamps...then wack the input heater hose...should be fun! Thanks again.
I just checked mine today coming in to work. AC max 46 deg F coming out of the vents. And on normal it was about 48 deg F. I'm going to clamp off the hose and test it again with the flow cut off to the heater core and see how much of a difference there is. The out come will help me make my mind up on whether to do this mode.
One thing though. The other hose coming out of the heater core comes out and loops down to a pipe. Does this go to the tranny? If it does would this cause the tranny to run hotter!
Going to look this hose up to see where it goes.
I'm sooo confused. Maybe Ford did use different Heater hoses over our model years. I guess what I'll do is buy a 3/4", go home and cut the hose and if the vavle's too big drop $5 in gas and make a return trip to HD/Loew's. Maybe I'll get lucky with the 3/4"?!
The "recirculate valve" is just the vacuum motor that controls the opening/closing of the recirculate door. Up under the dash by the passenger's feet. Remove the glove box to easily see it. Turn the AC on normal and MAX with the engine running and watch what moves. You should see a small vacuum motor with a lever on it that pivots back and forth. That is the vacuum line you want to tap into.
Edit:
Edit:
The valve is made by "Factory Air" Part # 84706 Shut - off Valve. Keep in mind this part number is only a reference. It is to small for my heater hose but it will let the parts peeps know what you need. Checker auto also had this part.
Heres the valve I'm getting from Napa.
http://www.eurekaboy.com/f250/heaterhose.htm
Shane,that is an overpriced POS "globe" type valve.But,if it works for you then thats all that counts!
I'm going to bring some valves home from work tomorrow and take some pics and post them here.I have access to almost any type of valve made and any configuration and setup possible!
BTW,I suggest using a 1/4 turn full port brass or stainless steel ball valve and brass or stainless steel nipples.
Post up those pics & cost for sure!
just a thought-if corrosion is a concern with the heater core how about closing the valve completely to stop the flow and then just cracking it open slightly. that would give some circulation of fluid but essentialy stop the volumn of hot coolant.
I think you are looking for this http://www.lowes.com/lowes/lkn?actio...BXB&lpage=none
I am going to pick one up today when I get off work (at 7am)
John
John
