Telescoping trailer towing mirrors finally on
Old Oct 4, 2012 | 08:38 PM
  #706
Average-Joe's Avatar
Anyone know what color the turn signal wires are in the cill plate.
I only have 4 wires going to the mirror so i need to run wires from the turn signal circuit ?
Old Oct 5, 2012 | 10:45 AM
  #707
jb07201's Avatar
Was wondering if anyone has or can get pins for me. Will pay. I don't like cutting wires. I like clean jobs
Old Oct 15, 2012 | 12:00 AM
  #708
04f150owner's Avatar
Originally Posted by over worked
Labman, I have a question, if you know. My truck is a 2004 F150 FX4 4x4 Power only, no heat or signal. I instaled the mirrors, changed the pins, wired the puddle lamps, changed the the fuse box to the heated mirror option. The power mirror, turn singal, and puddle lamps work fine. When I checked in to get a control module with the heated mirror button. I found that the 2004 with heated back window came with 4L3Z19980FB, When I orded the told me that I needed 7L3Z19980D and said that both the FB and the OD have been crossed over to the 4L3H-19808-BH, When installed the mirrors, turn signals, puddle lamps. and heated mirrors all work fine, but the ac selector for defrost. floor, vents etc.. does not work right. Any idea what would be wrong. Thanks
has anyone found a fix for the a/c mode door issue when changing hvac control heads? i have everything else working on my 04 f150 but i'm having the same issue above. i've tried pulling fuses for the hvac system to recalibrate the actuators but no luck
Old Oct 15, 2012 | 06:31 PM
  #709
Old Oct 16, 2012 | 01:02 PM
  #710
bump
Old Nov 11, 2012 | 11:09 PM
  #711
4x4fanatic2006's Avatar
Finally got those freakin mirrors after wanting them for 2+ years, plus a ranch hand bullnose...
Old Nov 11, 2012 | 11:12 PM
  #712
and one the other day before we put the bumper on (deer damage on bumper visible)
Old Nov 11, 2012 | 11:37 PM
  #713
Lifted5.4Lariat's Avatar
I still love these mirrors.. I think they help make my pickup.
Old Dec 3, 2012 | 11:53 PM
  #714
Craignolan's Avatar
Hey I just got some 08 power tow mirrors for my 06. My problems is that only the side to side power work. No up and down and no turn signal. Can somebody tell me wich pins need to be switched. I know there are two black wires out of place. One with a blue line. If switching those to the same place as the stock mirrors would work please let me know
Old Mar 14, 2013 | 11:02 PM
  #715
xplodn's Avatar
Finally got mine on. Switched the pins around for the Puddle lamps but was almost at a loss for how to run the wire to tap into the dome light then it hit me... Drill a hole in the connector body for the door harness and then just snake it through the rubber loom. Works perfectly and is very clean.
Old Apr 11, 2013 | 08:44 PM
  #716
Grabber70Mach1's Avatar
Hello hoping someone can clarify a question about installing these mirrors. I have a 2004 SCrew w/power/heated/TS mirrors now. I have purchased the TT mirrors, I understand the pin swapping and eliminating one ground on the connector. Also wiring the PL's up and running the wire to the PS for the PL. But do you have to make the same pin changes on the PS mirror plug? Thanks.
Old Apr 11, 2013 | 08:48 PM
  #717
xplodn's Avatar
Yes both sides are the same job
Old Apr 11, 2013 | 08:58 PM
  #718
Thanks for the quick reply, hoping to have time to tackle it this weekend.
Old Apr 11, 2013 | 09:01 PM
  #719
xplodn's Avatar
Its really pretty straight forward. Good luck!
Old Apr 29, 2013 | 01:37 PM
  #720
Got time to finish it up this weekend no problems and am rreally pleased with them. Thanks.
