Telescoping trailer towing mirrors finally on
Old Aug 4, 2008 | 09:37 PM
  #241
over worked's Avatar
mirrors finally on
I posted some pictures in my gallery of my truck with the mirrors on. Thanks for your help. over worked
Old Aug 6, 2008 | 03:33 PM
  #242
TascaFordParts's Avatar
Former Sponsor
Originally Posted by HotBlue05SCREW
Do you mind telling how much the mirrors cost and part number?
Black Mirrors 7L3Z17682AE & 7L3Z17683AE
Chrome 8L3Z17682DA & 8L3Z17683DA
See our site for pricing. www.TascaParts.com
Old Aug 20, 2008 | 01:27 PM
  #243
Labman, I have a question, if you know. My truck is a 2004 F150 FX4 4x4 Power only, no heat or signal. I instaled the mirrors, changed the pins, wired the puddle lamps, changed the the fuse box to the heated mirror option. The power mirror, turn singal, and puddle lamps work fine. When I checked in to get a control module with the heated mirror button. I found that the 2004 with heated back window came with 4L3Z19980FB, When I orded the told me that I needed 7L3Z19980D and said that both the FB and the OD have been crossed over to the 4L3H-19808-BH, When installed the mirrors, turn signals, puddle lamps. and heated mirrors all work fine, but the ac selector for defrost. floor, vents etc.. does not work right. Any idea what would be wrong. Thanks
Old Oct 8, 2008 | 06:51 PM
  #244
Centex's Avatar
These mirrors are great! Thanks for the tips on this thread - the install was a breeze.
TIP - for the puddle lights on a 2005 XLT, tap into the black wire with blue stripe that is in the bundle dropping from the dash to the BIG 53-pin connector (C238) behind the hood release handle bracket. That wire runs to pin 6 in the BIG connector (6-spaces up from the lower left corner of the connector). Undo the single bolt holding the hood release for lots of easy access room to make that connection for the puddle lamps - they'll behave like your delay shut-off dome lights.
BIG KUDOs for Tasca/Domenic: One of my mirrors arrived damaged; Dom shipped the replacement immediately and included the pre-paid return label for the broken item in that box. That is GREAT SERVICE.
Old Oct 11, 2008 | 10:18 AM
  #245
overlimit's Avatar
Just got my mirrors and thought I'd share.
Here is the easiest way to remove the wire from the harness.
1- Unplug harness
2- I removed the red cover on the front, but probably isn't necessary
3- Insert .035" wire into back side of wire you want to remove. Notice the relief in the harness?
4- With the wire inserted, gently pull on the wire and it'll come out.
5- Look at the orientaion of the adjacent pins and push it into the desired location
I used a Snap On pin extractor set borrowed from a friend, but anything that approximate size should do. A safety pin, music wire, a drill bit etc...
It'll take you seconds once you try it.
Old Oct 26, 2008 | 08:25 PM
  #246
high1's Avatar
Domenic,
Do you have the powerfold version of these mirrors as well? My '07 has them, but I would like to upgrade to the Trailer tow. Thanks in advance.
Mike
Old Oct 27, 2008 | 12:46 PM
  #247
Former Sponsor
Ford does not make a power fold trailer tow mirror.
Old Oct 27, 2008 | 01:02 PM
  #248
welfare wagon's Avatar
Then who makes the power folding one on the F-250?
Old Oct 27, 2008 | 01:10 PM
  #249
Former Sponsor
Let me re-phrase.
Ford does not make a power fold trailer tow mirror for a F150
Old Oct 28, 2008 | 10:30 AM
  #250
KevinCowtown's Avatar
I was so sure I saw a power folding mirror on an F-150 commercial the other day... but I just checked the website (http://www.fordvehicles.com/2009f150/) and it shows this same ('08) towing mirror and the copy says
Available on the new ’09 F-150 are manually
Telescoping/ Folding Trailer Tow Mirrors with large
viewing areas to let you see around and behind a large
trailer. They inspire confidence whether you’re towing or
not.
must have been a tricky camera angle or pan.
Old Oct 28, 2008 | 10:37 AM
  #251
GTRider245's Avatar
These are on my list of things to do...
Old Nov 6, 2008 | 08:45 PM
  #252
BIGTRUCKONE's Avatar
New to the forums but I need a little help please.06 XLT W/PUDDLE,W/TURNS,W/HEAT,W/POWER.Have put on 07 extending tows with all the same features but my defrost button flashes with the turns,no heat yet and no puddles yet.I think I know from all the disscusion how to get haet and puddles but how do I stop the flashing?As I said new and any help pics and diagrams would be a great deal of service to this lowly second time F-150 owner.(My beloved 1985 "brownie"and now the ghost an 06 xlt both 4wd)Thank you.
Old Nov 6, 2008 | 10:07 PM
  #253
blackjack8900's Avatar
Having a 06 like me you have to move the pins around on the mirror....did you?
Old Nov 6, 2008 | 10:44 PM
  #254
Not yet but,what pins go in wich terminals.I don't fully understand the whys as much as I do the how.Thanks for the help.More is always needed.
Old Nov 7, 2008 | 01:59 PM
  #255
LABMAN.Would ther be a chance of e-mailing me those schematics,or what not and maybe fill me in on the actual pin movement and what does what.Thanks a ton from the BIGTRUCKONE. SQ_IMPALA@YAHOO.COM
