Telescoping trailer towing mirrors finally on
Old Aug 2, 2010 | 10:30 AM
  #601
F150FXOnline's Avatar
I wrote all this down at home in my paper work. Ill post it later if u still need it.
BTW the chrome caps look sweet!!
Old Aug 2, 2010 | 11:30 AM
  #602
XPerties's Avatar
Nope, I did them that next morning. Took about 2-3 hours but that was due to running the wiring for the puddle lights. Everything looks great and works, now I just have to wait for v-led to get the puddle LED's back in stock. I placed my order but I'm just waiting for them to ship them.
You guys using RVD to reseal the puddle light lens after you take it off? Clear I assume.
Old Aug 2, 2010 | 11:58 AM
  #603
rednoved's Avatar
I used Loctite® Super Glue ULTRA Gel Control™
Then I used some Irwin Bar Clamps to hold it together for a while.
Old Aug 2, 2010 | 12:50 PM
  #604
XPerties's Avatar
I'll pass on using super glue just in case I ever want to take the lens back off.
Old Aug 2, 2010 | 03:17 PM
  #605
XPerties I may contact you in a few weeks if u dont mind. The reason I Havnt jumped on buying the chrome caps I should of bought them while I had everything apart but didnt know you could buy just buy the caps at the time and would have to remove the mirrors from the door! DOH!!! Im not real excited about taking the panels off again with having to unmount my componet speakers in the front and with other issues.
However there so cheap may tackle it in a few weeks. Still not 100% how you removed them from your pics but wont worry about it till I order the chrome caps.
Old Aug 2, 2010 | 03:41 PM
  #606
XPerties's Avatar
Yo bro, you don't have to remove the mirrors from your truck. All you have to do is remove the glass using a small flathead screwdriver to pop it out /(being careful not to break the glass), then remove 3 torx screws, push down on 2 tabs and the caps will pop right off.
The link I posted from another thread was helpful and using a small flashlight to view better behind the glass while using the screwdriver is also helpful. Just order the caps first so you have them when you get your others off.
Old Aug 2, 2010 | 04:15 PM
  #607
No way!!? I though the 3 torx screws were on the backside in the same place were the 3 nuts held the mirror on the door for some reason!!! Going now to orde them!
Ill look for the link again you post showing now to remove the glass.
Old Aug 2, 2010 | 10:01 PM
  #608
XPerties's Avatar
Nope they are behind the glass once you pop it off. If you tilt the glass at an angle (as far as it will go so you can get a peek behind it from one corner) you can see where you have to push the flathead in to pop it off.
These might help (ignore part about having to remove mirror from truck):
http://www.muthco.com/epapers/21000960.pdf
http://www.f150forum.com/f4/help-rem...-mirror-39407/
Old Aug 2, 2010 | 10:10 PM
  #609
rednoved's Avatar
Makes sense. I don't want mine to come off, so I used that super glue.
Old Aug 3, 2010 | 10:20 AM
  #610
Thanks again XPerties, I ordered the caps yesterday and will post pics after I get them installed before and after.
Old Aug 7, 2010 | 06:46 PM
  #611
Lifted5.4Lariat's Avatar
Alright guys i'm wanting to make my order with tasca for these. I have an 04 Lariat with Power, Heat, and Signal currently. When I put in the part numbers it came up with ones for an 07-08 and ones for 09. Would anything be different between these two? Like wiring? And could someone whos done this before on an 04 chime in also so I know it wont be too hard other than switching a pin and running a puddle light wire? Thanks I'd like to get these today or Monday.
Old Aug 7, 2010 | 07:34 PM
  #612
XPerties's Avatar
I have an 05 that had power, lights and turn and I swapped them out for towing mirrors off a 2010 Lariat and the only thing I had to do was:
Move pin 9 to pin 8 slot
Remove pin 2, cut the wire leaving a pig tail and move it to pin 11. Wire the pig tail to the black wire with blue stripe in the drivers door seal that is wired for the doom lights
....running the wire took the longest but everything works perfect. BTW the wire is for puddle lights and is not required if you don't want them or order them on your towing mirrors (if it's even optional).
Old Aug 7, 2010 | 08:06 PM
  #613
Sounds like a plan! Thanks alot man. I'm gonna place the order for them right now.
Old Aug 7, 2010 | 09:22 PM
  #614
Just to be sure. Here is the two that it is listing.
Collision Catalog
Item Number MSRP Core Price Price
7L3Z17682AE $175.00 $0.00 $134.75
Front door - Outside mirrors - Mirror assy - Power
Black Right - Towing 2007 - 2008
Add to Cart Contact Us
Front door - Outside mirrors - Mirror - Black
Black Right - W/trailer tow, w/heat 2009
I think i'm just going to order the ones that say 2009. Would it make a difference? They have the same part number. I just don't want to have a big surprise when they get here! Thanks
Old Aug 8, 2010 | 12:01 PM
  #615
Anyone?
