Fusion Key
It shouldn't be a problem b/c other ppl here on the forum has used it.
By the way I received my key but I haven't had it cut yet.
Ok, so let me see if i got this straight. You have to have two keys in order to prgram the fusion key? I only have one key(with unlock button). So can I just go have a key cut and then do the fusion key upgrade? Or do I have to go to ford and get a whole key with remote programmer thing?
Fusion Key
My Fusion Key just came in the mail and I tried to program the lock/unlock panic feature and it will not work. Any ideas! It is not cut yet I was trying to see if the key features would work.NOTHING I changed the battery with a new one. I bought it off Ebay. I guessing the frequencies are different. Please Help!
I have a Fusion key for my Mustang. I had programmed it to my 2008 Expy first to test it though. Worked just fine in the Expy, and now my Stang
did you try the programming procedure several times? the Fusion key works in all 2004+ F-150's that people have tried so far.
