Rafa26, Project Becoming A Reality .
Old Mar 13, 2007 | 10:16 PM
  #301
ThumperMX113's Avatar
I just hope Rafa is happy with the final product. . .
Old Mar 20, 2007 | 05:28 PM
  #302
rafa26's Avatar
Last update :
MonsterBox torque-converter it's not holding the power at full-throttle.
Truck needs a 3 plate torque converter .
Old Mar 20, 2007 | 05:57 PM
  #303
ktexas's Avatar
Keep your head up partner!
Old Mar 20, 2007 | 06:53 PM
  #304
Ancientmyth's Avatar
Glad to hear it's coming together. Wish I could see the beast once you get the torque converter issue dealt with. Let us know how it turns out.
Old Mar 20, 2007 | 07:59 PM
  #305
rafa26's Avatar
11 pounds of boost only ! Sounds good ?? Undertuned because of the fault torque converter !
Old Mar 20, 2007 | 08:01 PM
  #306
JimIII@jdm's Avatar
Former Sponsor
This truck is just simply a beast! with a triple plate lock up convertor it will make just as much or more than a built Whippled Lightning!
JimIII
Old Mar 20, 2007 | 08:11 PM
  #307
Virilha's Avatar
The fact of Rafa's truck having 4.56 gears and the wonderful 3 Valve heads, make more power than a built Whipple Lightning is a must.
Old Mar 20, 2007 | 08:29 PM
  #308
JimIII@jdm's Avatar
Former Sponsor
I agree the 4.56's Eat up alot of power! The 3V heads are bada$$ too!!
JimIII
Old Mar 20, 2007 | 09:44 PM
  #309
thetruck's Avatar
With proper equipment and everything else, what is the max boost you are going to be running Rafa? What HP and Torque numbers are you gunning for?
And JDM....where would I be able to get GOOD 3v heads?
Old Mar 20, 2007 | 10:31 PM
  #310
JimIII@jdm's Avatar
Former Sponsor
With the new pulley system we put together Rafa's truck should be every bit capable of 20+ psi. That would probably equate something around 700 RWHP 800 TQ but the only limits will be what fuel is used...
If you want some info on the same heads we used in Rafa's build and all our 3V engines give us a call at 732-780-0770, ask for me id be glad to help with any info you need! I just installed a set of these same heads on a 300 cu in 4.6 block with 11.5:1 compression that im building fpr my car (06 Mustang GT automatic). I hope to see close to 400 RWHP Naturally aspirated!
JimIII
Old Mar 20, 2007 | 11:20 PM
  #311
azfordby4's Avatar
It looks like things are moving in the right direction>
Rock on
Old Mar 21, 2007 | 12:03 AM
  #312
BABA4488's Avatar
Rafa are u goin to b spraying any Nitrous on this beast or would that be overkill?
Old Mar 21, 2007 | 12:45 AM
  #313
mSaLL150's Avatar
my god rafa your truck is rediculous. i just read most of this thread, goodluck with everything. im sure you've heard this 1000 times but be SURE to post vids plz plz plz
Old Mar 21, 2007 | 02:41 PM
  #314
rafa26's Avatar
Don't know yet man, i have to fix the torque converter issue first and get the numbers with 20PSI+ after the engine break in period.
Old Mar 21, 2007 | 08:28 PM
  #315
rafa26's Avatar
Rock on
I agree.
