Best Electric Fan Kit?
Old Jul 18, 2006 | 09:59 PM
  #121
RAYJAY25's Avatar
Originally Posted by blkscrew
fans are in as in installed in truck??
also for the switch is the one you used and if so where did you mount it??
any issues to look for while doing install....
I did notice I'll have to find some way of securing the positive batter cable as it's hooked to the fan shroud....
No Just got the fans!!! I am going to install them this weekend, after the dealer does the rear again!!!
That is the switch i picked up, The Switch can be mounted almost anywhere , you only have to drill a small hole.
I am also going to make a shroud (I don't like the ziptie idea, looks cheap)
I also got the pulleys in, so it will be a fun weekend!
I Have not looked at the Batt. Cable
PS--- the weather proof(?) fuse holder is not the best, so i am going to replace it before install!!
I will take pics of how it all go together!
Old Jul 18, 2006 | 11:42 PM
  #122
Padron's Avatar
It really sucks that I missed out on this They should extend the sale.
Old Jul 19, 2006 | 10:11 AM
  #123
Blackford's Avatar
Well im going to install my fans today my afternoon class canceled so everthing is working out perfectly.
Old Jul 19, 2006 | 10:55 AM
  #124
Tical84's Avatar
Looks like you're first. Don't forget the pics!
My fans have made their way to Illinois. Still 2-3 days until I get mine.
Old Jul 19, 2006 | 01:03 PM
  #125
azmidget91's Avatar
i should be getting a visit from the brown truck today but my box is a bit bigger then your guys jlt intake pullies efans and drop shackles
Old Jul 19, 2006 | 04:42 PM
  #126
FX4 Matt's Avatar
Registered User
you will have a fun weekend!
Old Jul 19, 2006 | 08:34 PM
  #127
Blackford's Avatar
Well got the fans installed, only trouble was getting the fan off and finding the AC wire.You should use the pulley puller it works alot faster and the AC wire for some reason wasnt getting power with the tester it took about 3hours total to install and its pretty simple nothing to complicated.So far all i have noticed is throttle improvement i havent been able to get on it.Feel free to ask ???s sorry i dont have a camera with me.
Old Jul 19, 2006 | 08:45 PM
  #128
gobra's Avatar
You need a pulley puller? Or do you mean the fan puller? Where did you tap into the ignition circuit?
Old Jul 19, 2006 | 09:11 PM
  #129
Blackford's Avatar
oops sorry fan puller I have an aftermarket remote start /locks system i tapped into under the steering wheel to a pink wire i believe, i also had to use some spare wire to do that. my truck is an 04 4.6L just incase the wiring is different.
Old Jul 20, 2006 | 04:43 AM
  #130
blkscrew's Avatar
heres the tool for fan removal....
Blackford.....I've heard the fan is mounted with lefthand threads is this true?? also did you run a manual on/off switch for the efans....
Old Jul 20, 2006 | 07:46 AM
  #131
Blackford's Avatar
no i didnt use a manual on/off swith i dont have a use for it. regading the fans i believe your correct
Old Jul 20, 2006 | 07:53 AM
  #132
Blackford's Avatar
You really dont need to worry as soon as i put the fan puller on and gave it agood pull in the right direction it came off, i woudnt bother trying to use wrenches or anything i tried for thirty plus minutes and didnt get any where, took a quick trip to autozone and got a fan puller
Old Jul 20, 2006 | 02:58 PM
  #133
FX4 Matt's Avatar
Registered User
anyone gonna post some pics?
Old Jul 20, 2006 | 07:48 PM
  #134
blkscrew's Avatar
I'll try to remember to take a few pic's when I install mine next week sometime...
Old Jul 20, 2006 | 09:04 PM
  #135
xplorgee's Avatar
My fans still havent shipped. I was told today they might ship by the end of the week. That would be great. Any good wiring diagrams for the dual controllers and manual LED switch?
