Best Electric Fan Kit?
Just got my fans installed. I did everything but the switch because I dont have a drill that can hold the 1/2'' bit. I got all the wiring for the switch. The temp probes dont seem like they want to stay in there too well. Does anybody have any suggestions. The fans run like a champ but causes a little vibe sometimes when you just turn on your ignition w/o the motor. If anybody wants pics, I can do that. Most of the time was wiring and making it look pretty. If anybody has any good suggestions about the probes, help me. Is there a high temp sticky substance that can be used on the radiator w/o breakdown and smell.
I'd like some pics if you don't mind. I'm mostly wondering about controller placement and how you got to the fuse box and make it all look good. I'm polling everyone as I can't install mine until Monday I should have just about every way to do it.
Ill try to take some pics tomorrow b4 I go to work. I might be getting a new controller in the next year so I did a temp good job. It was good to me. Still having problems with the temp prove arrangement. I hate how you have to shove them in the radiator. Just doest feel right.
I got some copper gasket stuff that can stand up to 700 degrees. I dabbed a little on the probes. You can pull them out but they wont fall out. Thats all that matters. I like the fans but one creates a bit of vibe. I also found that the fans turn on at different temps sometimes. Its really weird. I was there are markings with temps. im using my edge to check my temps.
