Best Electric Fan Kit?
ok ok ill get on it i had some trouble myself putting them in and was pretty pissed when i poked a hole in my radiator and then couldnt figure out which fuse it taps into but figured it out and fixed the radiator and havent wanted to had time yet but i should have something writen up tonight i have quite a few pics during the install
sorry for the delay
sorry for the delay
ok my oppinion on the efans is they are not worth the price troyer charges however for the price of that group buy a few weeks ago and even for the regular price on jusnesmodified.com they are worth it and the extreamly colder a/c is very worth it
questions for you's that have already installed.....
how much extra wire did you need??
switch power from the radio fuse??
manual switch installed?? benefits there of??
LED indicator lights??
was the A/C noticibly colder??
probably takle mine in next few days....if I don't melt trying....hot as all get out here lately...
TIA,
TIA,
i started on mine at about 9 at night
i used 2-3 rolls of wire each being i think about 15 feet but could probably get away with 1-2 if you dont do the manual switch and this is with mounting the controlers on the drivereside
i mounted a manual switch just for the heck of it
use the number 1 fuse
i ordered some prewired led's from www.oznium.com
a/c is much colder
a/c is much colder
i used 14 guage wire and no diodes i just hooked the first one up to turn on a a certain temp then also to a manual switch, the second fan is turned on by the a/c or if the engine getts really hot but no manual switch
which wire for A/C turn on?
the turn on temp i just left it where it was in the instructions it says it is set at 160 then turned up the second one a bit
if you look at your ac compressor there are 2 wires coming out of it follow those up and they will budle up with some other wires but i cut open the loom at the valve cover(passenger side) and it is the gray and white wire
Fans are in my city per the local shipper. Woo hooo. Spent about 50 bucks in parts from Radio shack. There expensive but the only place around here. LEDs, wires, switch, splicers, butt connectors. They add up quick. Ill try to make a picture install write up when I start. Try is the key.
Originally Posted by NASSTY
Has anyone that recently installed the fans noticed an increase in horsepower?
biggest thing I did notice was condensation on my dash vents
....A/C is noticably colder while sitting idling....which the reason I wanted the e-fanssorry no piccies....bloody camera battery went t*ts up.....
What temp is everyone useing to turn your fans on.... I checked out Troyers site and from what I read it says 210 is where you make the best power and get the best MPG..
I never had Efans before ,Just like to know Thanks .
