Edge Update
Old Jan 25, 2006 | 10:38 PM
  #31
MosineeFX4's Avatar
Thumbs up
Originally Posted by hmfic
Anybody else notice the lower idle after the update?
Did the update earlier....went for a drive all seems good. My idle when warmed up is right at 600 rpm. Actually before the update my fast idle with level 2 on the edge was about 1800-1900 rpm, which was the only problem I was having. I was going to contact Edge tomorrow, but it looks like I don't need to anymore.........normal idle and fast idle are where there supposed to be after the update.
Old Jan 25, 2006 | 10:59 PM
  #32
hmfic's Avatar
Mine was in the low-mid 500's so I upped it to around 600+. All good now.
Old Jan 25, 2006 | 11:10 PM
  #33
CO FX4's Avatar
I was reading the other post on the Edge and customer service. Seems I have the exact same problem as Mire7's friend. I can't understand why I had zero problems and only smiles before this damn update, and now I have a dead truck in the driveway.
Old Jan 25, 2006 | 11:14 PM
  #34
Mire7's Avatar
call edge man asap they told me to send in the pcm and the tuner they will take care of the problem 1st class service after all
Old Jan 26, 2006 | 02:31 AM
  #35
Kool Aid's Avatar
Originally Posted by CO FX4
Disconnecting the negative terminal on my battery didn't help. I still have the wrench illuminated and no start, nothing. I even tried to retrieve DTC codes with the programmer, but it just sits there. I tried loading the level 1 tune and it gave me the same message when I try and return it to stock, "This programmer is locked to another vehicle. Please return original vehicle to stock before programming." Everything worked so well before this update. I'm screwed at this point.
Yes, I had returned it to stock before leaving work, got home with no problem.
It's not just returning the truck to stock, it's resetting the Edge unit itself to stock.
Did you read the directions?
Sounds like it's too late.
Old Jan 26, 2006 | 03:01 AM
  #36
Nates06SCab's Avatar
I think this will have to wait until I get the S-10 back on the road (dead Optima yellow top), so I can be sure I can get to work....
Old Jan 26, 2006 | 08:54 AM
  #37
PenguinFX4's Avatar
and do us a favor and paint that thing while you're at it!
(j/k)
Old Jan 26, 2006 | 09:05 AM
  #38
CO FX4's Avatar
I think it's done more than that, somehow. Yes, I had read the directions and I've used the software and all before. It was this update that caused this, I'm certain.
The Lightning software does have an option under Utilities to Restore Evolution, but it asks for a key, which I have no idea what the key is. That's what I'm hoping the Edge tech's can help me with when I call them promptly at 8am. Thank goodness I'm in the same time zone as them.
Old Jan 26, 2006 | 09:15 AM
  #39
JackDob's Avatar
Exactly my thought. The key could be programed to open up specific debug options that will allow you to do specific functions.. and allow you to use the stock.bin file to restore the PCM. If emergency restore is not an option they need to modifiy the firmware again. Knowing that I have that option would give me a warm feeling ....
Currently I only change the PCM code in my driveway so if there is a problem I won't need an immediate tow. Once we you have resolution I will make sure that I follow those rules. I work with computers and load code all the time and know when I flash those computers if anything goes wrong recovery is not straight forward.
Thanks for keeping us in the loop..
Jack
Old Jan 26, 2006 | 01:33 PM
  #40
CCRider's Avatar
How about an update? I'd like to hear what the solution was!
Old Jan 26, 2006 | 01:50 PM
  #41
04NickySP2's Avatar
Originally Posted by Tical84
How long did it take to install the update? I've been waiting for about 8 minutes now :o
(Cable internet 7Mbps)
Nevermind, I tried on a second computer and it worked. I hope nothing got screwed up when I tried it the first time.
It didn't take more than 30 seconds for each file to download. Then another 2-3 minutes to upload the new files.
Kinda funny watching the new mpg readout drop to 1-2 mpg when taking off from a stop.
Old Jan 26, 2006 | 01:54 PM
  #42
FX4_Guy's Avatar
I hear ya. I had to switch to another PID. The mpg was jumping around too much for my tastes. I also can't stand the rpm PID...due to the same problem.
Old Jan 26, 2006 | 02:24 PM
  #43
CO FX4's Avatar
I'm working with Edge still on this. I'm told they are building a stock writer program for me to use. I've given them my Hex code, and I hope to hear back from them soon. I will say, despite this problem, that their customer service has been pretty decent. If they get me up and running soon, I'll be very happy. I'll update here once I've got the cure.
Old Jan 26, 2006 | 02:31 PM
  #44
Tical84's Avatar
I got it downloaded on my other computer. My girlfriends laptop is always jacked up.
I've already played with the MPG reading. I noticed when coasting it doesn't go higher then 50.0 MPG. Makes sense I guess since we can't coast forever and will never see anywhere close to that anyways.
Old Jan 26, 2006 | 02:42 PM
  #45
expy03's Avatar
I have to wonder why Asinatra has had so many problems with customer support. Things that make you go MMMMMM...............
