Q & A about the Edge product for 04-06
Originally Posted by CO FX4
Jay (bbjones56) Thanks for getting on here and responding to some of our questions. I am in the group buy and I've been wondering if the evolution's tunes do anything for lower end rpm improvement, ie., downshifting, better throttle response, and such in the 1500-2500 rpm? Generally these tunes make claims in the 3k+ range, but lower would be great. This would be with an of the levels 1-3.
Also, you mention that aftermarket mods will enhance. In an earlier post MSEmechanic mentioned that Edge "may even" provide adjustments for a particular mod, such as an AFE intake vs. Airaid, Gibson exhaust vs. Magnaflow. Is this in the future? Or is it on the "white board" for possible implementation?
I look forward to getting the evolution. Any helps, FAQ's, and support you can provide on your website for users will be much appreciated!
Merry Christmas :santa:
Our bases levels are designed for stock trucks. Our Beta testers have had a variety of trucks with modifications and they all loved this programmer. Some wanted the shifting to be firmer, while others didn't want it so firm. The great thing is that you can change it to your liking with just a couple pushs of a button. We might come out with downloadable tunes for certain modifications down the road. That is a great idea and if you desire them, please call into our tech support and tell them what you would like us to develop. They in turn could tell our management and if they get a lot of response for a certain thing, then it just might happen.
I hope this answers your questions.
- Jay
Originally Posted by Tical84
I have a question...
When looking through the 19 things this does I noticed everything is imperial. Do you have a metic version for the Canucks?
- Jay
Originally Posted by Jims05Screw
Smeezy or any other Beta testers,
How does the moniter snap into the POD. Can it be removed fairly easy?
I hope that wasn't too confusing. It all makes since in my head. If you have more questions, please ask!
Originally Posted by FX4_Guy
Does anybody know if there is a pdf manual floating around for this thing? I wouldn't mind getting my hands on it before my turner comes in.
- Jay
Originally Posted by bbjones56
When I get back to work (around Jan 3rd) I'll try to post up a manual.
- Jay
- Jay
Question:
I keep looking for more product info and download information on the EDGE website but I don't see it. So I assume that the software that comes with it will link up to a secret or hidden page or will something be active shortly.. ?
Jack
Im curious to understand this . . .
Most tuners you can change parameters but does the tuner have a max/min so that you cannot self destruct your motor? Im probally going to be leaving my tuner the way it comes from Edge but Im curious to understand this . . .
is there a way to just hook the tuner up to get the readouts? my thought was to do the 60' times and 1/4 mile times in the stock configuration, get the data, then do the same in the 91 tune to see the difference....i believe there is a formula to plug in truck weight and the times to get hp and torque numbers....? i don't have access to a dyno and i was just curious. any thoughts? or do you have to plug in and download the program then switch to stock mode????? thanks.....
I guess I have a question also if anyone knows. Does the Edge power off when the key is off?? With other tuners, when you plug them in with the truck off, they still get power from that diagnostic port. Just wondering if there would be an issue of running down the battery if the cable is left plugged in all the time.
Originally Posted by rculpepper02
I understand that when I take the truck in for service I need to put it back in Stock Mode, but I was wondering if this will affect my warranty in any way?
Uh...no
Ya, they are going to void your warranty, no questions asked.
Bill
05 scab lariat
Originally Posted by billindenver
Uh...no. Not only will they not do that, but they can't do that. IF they can reasonably prove that your mod directly CAUSES a failure they can refuse to fix THAT ONE problem under warranty. They can not simply flush your warranty due to a modification. I believe the law is called The Magnuson-Moss warranty act....or something resembling that.
Bill
05 scab lariat
Bill
05 scab lariat
