Rear sway bar = night and day difference!
Old Feb 6, 2006 | 10:22 AM
  #91
ford2004F150's Avatar
Originally Posted by F150 Duke
So has anyone actually installed this on a 4X4 with SIDO exhaust?
Duke
I have!
And yes it does require modification to the exhaust to get it in.
I have a Borla Cat back setup.
Old Feb 6, 2006 | 10:32 AM
  #92
CCRider's Avatar
Originally Posted by ford2004F150
I have!
Which sway bar did you install? The Belltech and the Helwig mount totally different......
Old Feb 6, 2006 | 11:11 AM
  #93
F150 Duke's Avatar
I have!
Any pics? What did you have to modify to the exhaust?
Duke
Old Feb 6, 2006 | 11:21 AM
  #94
SSCULLY's Avatar
Originally Posted by Thrill Racing
...<snip>...
So if you want a rear swaybar and also wheel occasionally. just get quick disconects and disconect the rear while wheeling or for the winter, if the ice issue bothers you. When I install all of this I will also maybe make a bracket the sway bar can be attached to while not in use, if this is done copiuous amounts of pictures will be included.
-Will
I don't know why it would need to be disco'd.
The H2 does not do too bad with off roading, and it is not disconnected when doing this :
This is one serious Rear AntiSway bar, and on freeway ramps, the H2 hugs like mad. It actually does pretty damn good for a 8600 GVWR rig.
Old Feb 6, 2006 | 11:25 AM
  #95
spotbearsd's Avatar
Last week, I called Belltech directly and they told me that they would not guarantee their 2WD rear sway bar will work on a 4wd. They have done no R&D on it as of yet.
Helwig is the only company that currenty promotes actually making a rear sway for '04-'06 4wd F150.
Old Feb 6, 2006 | 11:27 AM
  #96
Red05stx's Avatar
cc, can you post a link to your gallery. I cant find your pics.
Old Feb 6, 2006 | 11:44 AM
  #97
SSCULLY's Avatar
I could see how a DO straight out the back might need some modifications with the Helwig. You can see the factory run in this picture:
I can scan the complete instructions into a PDF and email them if anyone wants them. Drop me an email in my profile if you want to read through them prior to deciding on which one you want. BTW these arr the 4x2 instructions for the rear only. The Helwig P/N is 7663.
Old Feb 6, 2006 | 11:50 AM
  #98
CCRider's Avatar
They are in there............ Try again! http://www.f150online.com/galleries/....cfm?num=10414
By the way, the arms of the Belltech bar mount forward of the rear end.
Old Feb 6, 2006 | 12:59 PM
  #99
I installed the Hellwig... if you'd like I'll take some pics tonight and post them for you.
Old Feb 6, 2006 | 01:08 PM
  #100
CCRider's Avatar
Thanks, I'm sure any photos you post will be of value to anyone trying to decide which bar might work best for their particular setup............
