Bye Bye Auto Spring
Old Sep 21, 2005 | 08:27 PM
RED WING NUT's Avatar
Originally Posted by freekyFX4
So, do your aftermarket wheels and tires fit without the levelling kit and blocks?
The rims are stock, no problems. With a different offset/backspacing, there might be some problems.
Old Sep 21, 2005 | 08:31 PM
freekyFX4's Avatar
Originally Posted by ThumperMX113
What I was saying was..
My leveling kit was a temporary fix until I could afford the full suspension lift and now Im going to do the full suspension lift before my system because I had a look at them yesterday. The coils arn't looking too good, in some spots the actual spring is dented in and some other places the rubber coating is worn off. Does anyone know how much these coils cost?
I understand now...I guess it just doesn't bother me that much. I just hate the little clunk.
Old Sep 21, 2005 | 08:46 PM
BlazinSTX's Avatar
Autospring is the leveling kit that contains the bushings correct? Where you have to disassemble the strut? I have the EZLift, (spacer only) and i havent seen or heard any rubbing, denting or clanking of any sort. Ill give it a thorough look through tomorrow... man, that sucks for everyone with Autosprings kits.
Old Sep 21, 2005 | 08:49 PM
ThumperMX113's Avatar
It won't be as bad if you don't do any offroading. I do offroad so I think that only made it worse.
If your going to look at it, your going to need to take the wheel off to see any of the damage.
Nope, just a 1 5/8" spacer on top of the strut.
Old Sep 21, 2005 | 08:52 PM
Mine's never been offroad.
That sounds really sad doesn't it?
Old Sep 21, 2005 | 08:56 PM
BlazinSTX's Avatar
HAHA! I hear you brotha.... I do have to admit, ive taken my truck offroad
exactly 0 times since the leveling kit intall. Sad it is..... :o
Old Sep 21, 2005 | 08:58 PM
nvrenuff's Avatar
I think the problems are with the 2" block, the 1 5/8" blocks are ok, at least mine is and I do a lot of offroading. Autospring even warns that the 2" block may bind.
Old Sep 21, 2005 | 09:02 PM
Read again. Mine was the 1 5/8" thick spacer that lifted the front 2 1/4". I thought mine was OK too but it proved me wrong over time.
Old Sep 21, 2005 | 09:07 PM
kd4crs's Avatar
The clearance of the control arms and the sharper angles are the reasons I decided not to install the 2" Autospring kit I bought. I sold it and put 2" drop shackles on instead.
Old Sep 21, 2005 | 09:09 PM
Originally Posted by kd4crs
...put 2" drop shackles on instead.
I just took out the blocks under the rear springs. Free.
Old Sep 21, 2005 | 09:14 PM
blacklariatfx4's Avatar
Thumper,
I wouldn't worry too much about pricing the factory springs, especially if you're going to do a full lift later on down the road. I've noticed some "rubs" on my coils too, but I plan on doing the Fab-tech w/coils so I'm not overly concerned.....not concerned at all.
Old Sep 21, 2005 | 09:17 PM
freekyFX4's Avatar
Originally Posted by blacklariatfx4
Thumper,
This is exactly what I was thinking!
Old Sep 21, 2005 | 09:26 PM
nvrenuff's Avatar
I think I'll go check mine over again, this time a little closer.
Old Sep 21, 2005 | 09:52 PM
-TXF150-'s Avatar
Im glad I waited and did the 6" Fabtech insted of the autospring.
