Back-up Camera's
Old Jan 29, 2005 | 03:14 PM
AKFX42004's Avatar
Back-up Camera's
I did a search and found nothing. Were is everybody mounting back-up camera. i was thinking about in the hitch but it might be to low.
Old Jan 29, 2005 | 04:49 PM
GordoPanocho's Avatar
Registered User
Several 'answers' for you ... several forum users have camera setups.
https://www.f150online.com/forums/sh...ghlight=backup
https://www.f150online.com/forums/sh...ghlight=camera
www.hitchcam.com ... would personally go for the FrameCAM in order to keep hitch free and clear for use, etc. Plus, this would help line up whatever you're about to hook up for towing.
Seach ebay for (hitchcam,framecam) and/or camera +(backup,back-up).
http://search.store.yahoo.com/cgi-bi...y/nsearch.html
Old Jan 29, 2005 | 05:37 PM
AKFX42004's Avatar
thanks for the info. I found a few on ebay. i will have to wait to see where i want to mount it when I get it in.
Old Jan 30, 2005 | 01:28 AM
speedwolf's Avatar
I got mine off of eBay. See my pixs for the install. There's a hole already in the steel bumper, just had to drill through the plastic cover. It's located just to the left of the license plate.
Old Jan 30, 2005 | 01:52 AM
RamSS/T's Avatar
Speedwolf...I really like your camera install!!! I just found the seller and plan to buy one just like and copy your intsall (you would recommend that camera wouldn't you...have you had any problems with it?) How did you do the power wire for the camera...does it come on when your truck goes into reverse (triggered by the same wire that triggers your HU to show the camera image) or does it stay on when the truck is on? I thought about using the backup light wire....will that work? THANKS!
Old Jan 30, 2005 | 02:59 AM
AKFX42004's Avatar
do you have it so it come on when you put it into reverse, if so how did you do it
Old Jan 30, 2005 | 08:38 AM
4 da boat's Avatar
I was thinking of moving it up on the shell like the "UPS" trucks have it.
Old Jan 30, 2005 | 06:46 PM
Registered User
Looks like AKFX42004 got a few good replies on Ford Truck World as well ... for those who are also looking for back-up camera options, pics, etc.
http://fordtruckworld.tenmagazines.c...-backup_camera
Old Jan 31, 2005 | 06:36 AM
petersde's Avatar
That was one of my first mods . I used the receiver for mounting and it does not interfere with the hitch. Works well except for the outer corners of the vehicle. I've found it to be a great help.
Old Jan 31, 2005 | 12:24 PM
speedwolf's Avatar
I've read of some people hooking it up to the reverse lights so that it comes on when the truck is put in reverse. I wired mine all of the way up to the head unit, so it is on all of the time (use it when towing a trailer with my motorycle on it to check on it from time to to time). Either way will work. Eventually I'm going to install a small switch somewhere in the dash to manually turn it on when I want to and off otherwise.
If you're only going to use it for backing up, just wire it in to the reverse lights. If you want to use it at any time, wire it up to the head unit like I've done.
