project *no payment*
Old Apr 14, 2013 | 07:52 PM
  #31
MyFX4Project's Avatar
This build is awesome!!! Your interior looks great! I want to eventually get a beat up pickup for cheap that i can piece together and restore a little bit.
Thats pretty impressive how you got the 4x4 shifter to work with the console. I know a guy that tried the console and gave up when the saw the shifter wouldnt fit around it.
Old Apr 16, 2013 | 01:23 PM
  #32
autotech88jtaw's Avatar
gas tank change
Old Apr 16, 2013 | 01:24 PM
  #33
tank in
Old Apr 16, 2013 | 01:27 PM
  #34
this took 4 hours!!!! after patching all the rust holes in the back i could finally add some fabric to the back and then finally add the seats and bolt them down, they also still fold forward too
Old Apr 16, 2013 | 01:29 PM
  #35
Old Apr 16, 2013 | 01:31 PM
  #36
Old Apr 16, 2013 | 01:33 PM
  #37
frame fix, it was not cracked or broken , but it did have some holes on the bottom so better safe than sorry
  #38
Old Apr 24, 2013 | 01:47 PM
  #39
its been awile since i have posted some new pics of work being done but to catch you all up i am in the process of replacing the passenger side manifold, due to it being welded and also due to it having holes in it, luckily we didnt break any studs off inside the head and it didnt take us very long to get everything ready, now just waiting on a new manifold
Old Apr 24, 2013 | 01:49 PM
  #40
is the hole in the upper left hand corner supposed to have a freeze plug in it or is that the lifting hole to lift the engine?
Old Apr 24, 2013 | 03:45 PM
  #41
Alex_4.2L's Avatar
Project no payment-thats a great name for a project. Im subscribed.
Old Apr 24, 2013 | 07:17 PM
  #42
bchauler's Avatar
Remarkable amount of rust. What part of the country are you in?
I too have been working on a $1000 truck.
Old Apr 25, 2013 | 05:05 PM
  #43
i live in great ole northern ny, a little farther north than watertown ny, and yes the rust is crazy up hear , so much so i wasnt sure if i was going to be able to save this truck
Old May 2, 2013 | 04:23 PM
  #44
ok so i just wanted to give an update, passenger side exhaust manifold is all bolted up and the transmission tube had two holes in it, since i didnt have a replacement and the 4.6l tranny tubes are different i had to fill the holes with gorrila glue and it seems to be working, i also had to remove the broken bolt from the tranny tube mount, now the tube doesnt flop around anymore and is solid. pics will come of that later
Old May 2, 2013 | 04:26 PM
  #45
I also had a continous battery light come on so i had to replace the alternator with one from a 2000 expedition, the alternator was a little larger but it worked. i also have a misfire, so i am currently taking out all the cop's and replacing them along with the plugs
Also, the furthest back cop on the passengerside had antifreeze in the plug hole so everyone knows where that is coming from, yup the heater core houses so i have to wrap them up, instead of replacing them
I also did not have 4wd so i replaced the two solenoids and now the 4wd works, so lots and lots of stuff done on this truck and more to come
