Truck feels like its misfiring
Old Dec 27, 2009 | 03:57 PM
4x4wolf's Avatar
Its been pretty cold here the last few days, hadn't got out and started my truck in 3 days. It started fine, let idle for like five minutes to warm up since it was still in the twenties. Drove to gas station just fine, then on the way home when it shifting back into first when at stop lights it felt like the truck was misfiring and shaking. It did that only in first gear when got into second it was fine and smoothed out but when went back into first it did it again. No check engine lights or other warning lights. Any ideas?
Old Dec 27, 2009 | 04:08 PM
jethat's Avatar
probably a coil on its way out. what engine? Missfires sometime get stored for awhile as pending codes. You could have it scanned and it might give up what one. If youve never done it you may want to buy the coils on e-bay search "dg508" $65 plus shipping last time i looked. might do the plugs and all if you haven't ever done them. motorcraft plugs torqued to 28 lbs dry no antisieze dielectric grease on the boots.
Old Dec 27, 2009 | 04:13 PM
Raptor05121's Avatar
did you put gas in it? possible water contamination.
Old Dec 27, 2009 | 04:16 PM
4x4wolf's Avatar
Just had the plugs done in June and no I didn't put any gas it. Any chance I'm bout due for a fuel filter change that it could be that?
Old Dec 27, 2009 | 04:23 PM
they say change it every 10K miles. it wouldnt hurt to do but i doubt its the problem
Old Dec 27, 2009 | 04:41 PM
BlueOval_Man's Avatar
Wow. First time mine has been changed 96k today.
Old Dec 27, 2009 | 04:45 PM
jethat's Avatar
get the codes pulled. Then take a coil from another cylinder and swap them. if the miss move you have a bad coil. I'm going to say there is a 85 percent chance thats the deal anyway. If it were me I'd just order them e-bay coils. Save the good ones in case 1 fails in the future. if you have never replaced them its due.
Old Dec 27, 2009 | 04:46 PM
jethat's Avatar
Bet it was clogged. That can cause premature pump failure..
Old Dec 27, 2009 | 04:53 PM
4x4wolf's Avatar
Thanks for the suggestions guys, its like 25 degrees outside and I don't wanna be working on something that isn't going to help
Old Dec 27, 2009 | 05:24 PM
Oh well, theres more money in the world to earn. Truck was running fine, so I dont think it was too bad.
Old Dec 28, 2009 | 03:05 PM
autotech88jtaw's Avatar
My truck had the same problem, but for me it did set off the checkengine light. so i put the scanner on it and #3 cylinder had a missfire, come to find out my heater core hose was leaking antifreeze and it was going right into the spark plug hole, fouling the plug and causing it to missfire, i got the hose fixed and put a new spark plug in and now its as good as new
Old Dec 28, 2009 | 03:35 PM
mcolford's Avatar
I as well had a problem with the coolant running down and screwing the plug. It would only do it after the motor was nice and warm, very odd, but I finally figured it out when I noticed a drip of green ontop of my plug wire.
As for you, just go get the codes run, that will give you a basline as to where you need to trouble-shoot.
-Matt
Old Dec 28, 2009 | 06:01 PM
4x4wolf's Avatar
Been driving to and from work the last two days and nothing so I don't know what
Old Dec 29, 2009 | 12:34 PM
AZTriton's Avatar
If the problem hasn't repeated itself, I wouldn't worry about it. Your IAC could have been acting up or could have been an engine fart!
Old Dec 29, 2009 | 06:44 PM
4x4wolf's Avatar
Still going fine
