what tire pressure for a 265/70/17?
Old 01-28-2007, 06:49 AM
bewtew's Avatar
i want even wear as much as possible (and yes i do rotate) with the best traction i can get out of. please provide input.
Old 01-28-2007, 09:20 AM
wandell's Avatar
I've always had good luck with 40 psi in truck tires.
Old 01-28-2007, 10:16 AM
kingfish51's Avatar
What is the load range and and max psi of the tire. That size comes in P series to LR E. Size is not enough info.
Old 01-28-2007, 12:32 PM
mgsalida's Avatar
I agree with Wandell.
Mike
Old 01-28-2007, 12:57 PM
chrism9232's Avatar
i run 40 psi in my 265/75/16
Old 01-29-2007, 05:27 AM
bewtew's Avatar
ok will try this out. thx guys
ill take a look when i get the chance
Old 01-29-2007, 07:22 AM
kingfish51's Avatar
Don't put 40 in if that is a p series standard load tire. That would be about 5 psi over max for the tire.
Old 01-29-2007, 03:58 PM
Silver05screw's Avatar
It says the max tire pressure on the tire. Don't go over that, and keep all four tires the same.
Old 01-29-2007, 07:25 PM
bewtew's Avatar
addtnl info checked
k more tire info
265/70/17 113s max psi 44 standard load
suggestions then?
Old 01-29-2007, 08:05 PM
kingfish51's Avatar
That is a P series extra load. 38-40 should be okay with that tire. Just keep an eye out for abnormal wear and adjust accordingly. You probably won't need to go any higher, but may be a bit lower, although I wouldn't go any lower than 35-36.
Quick Reply: what tire pressure for a 265/70/17?
