Go Back   F150online Forums > Powertrain & Mechanical > V8 Engines
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
V8 Engines SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 12-29-2008, 10:42 AM
Garage is empty, add now
Vehicle: 2004 Ford F150
5.4L 3V Owners: Check your Champion 7989 Replacment Plugs!
Round 1 - 12/29/2008
If you've swapped out your 2 piece plugs for the champion 7989 replacement plugs - check them. After a searching relentlessly for a low grade mis fire, after having the computer changed (it died), swapping all the plugs to the champions, dealing with broken plugs, and about to swap all the coils at $45 each, I said, well, just for ****s and giggles, I'm gonna check the "NEW" plug on the cylinder that was throwing the CEL. This is what I find.
Does anyone think this might be why I'm getting a misfire?
Does Champion warranty their plugs?
Click the image to open in full size.
Round 2 - 12/14/2009
I figured that I would resurrect this thread from the realms of the archive to show the newest plug burn.
Pulled this plug out of no 7 cyl. Now, if I was smart the first time around, I would have noted which cylinder I pulled the original plug out of swapped COP's with. I believe I pulled the first plug out of no 6, and could have swore that I swapped the COP's between 5 and 6... but I could have very well swapped it between 6 and 7 because they are easier access.
I took all the champions out and went with Motorcraft SP462 / PZT1F, and just like the first round of plug swapping, I used nickel antiseeze on the sleeves.
I'm not sure, but I think something is missing.......... (that's sarcasm)
Old 12-29-2008, 10:56 AM
Vehicle: 1997 Ford F150
Send a message via AIM to Faster150
thats damage from prolonged detonation. not really cause of warranty
Old 12-29-2008, 11:00 AM
2005 Ford F-150
Vehicle: 2005 Ford F150
Good grief! How many miles were on this plug? It almost looks like the nose has been destroyed by preignition, doesn't it? Except, preignition usually eats up the electrodes.
I wonder if you're running lean?
Faster150, you're too quick for me! I agree that detonation is a good guess too. UCF-150, have you pulled and looked at any of the other plugs?
- Jack
2005 KR 4x4 SCrew 5.4, "Gott's" style CAI, PHP Gryphon CTS Tuned
Last edited by JackandJanet; 12-29-2008 at 11:05 AM. Reason: Added note to Faster150 and UCF-150
Old 12-29-2008, 11:54 AM
Vehicle: 1999 Ford F-150 5.4
I knew there was a reason I hate champion plugs. I wouldnt put one in my lawnmower.
1999 F-150 xlt 5.4 4x4
1971 Mach 351c 5 speed TKO600 Tremac-sold!
Old 12-29-2008, 12:47 PM
no, I haven't pulled any other plugs, but i will. The plugs only have about 9k miles on them.
Old 12-29-2008, 05:08 PM
Quote:
my dads theory was they are champions of the trash can.. thats about it
Old 12-29-2008, 07:15 PM
Vehicle: 2008 Ford F150
Send a message via Yahoo to risupercrewman
Dude, thats insanely crazy!.....Thanks for the post!
Old 12-29-2008, 08:30 PM
so whats the cause of prolonged detination / predetination??
Old 12-29-2008, 10:08 PM
Quote:
lean burn. to much timing. or to little
Old 12-29-2008, 11:09 PM
My dad never let us put anything made by champion in any of our cars!!
Old 12-29-2008, 11:17 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman
04+ = excessive lean conditions anyways to squeeze MPG's out of a heavy turd truck
Dual Bullets X Patman LED tail lights X Custom Sub Box
Reverse Fogs X 5/7 Drop X Jmod X Console Shifted
Quote:
Originally Posted by Raoul View Post
Under my umbrella ella ella ay ay ay
Old 12-30-2008, 08:34 AM
Vehicle: 1981 ford bronco
Why are you running Champions? Is your truck a two-stroke? That's all a Champion is good for. Can't tell you how many running problems I've looked at and all I did was replace the Champion plugs with Motorcraft and problem solved. Ford motors don't like Bosch plugs, either by the way.
Old 12-30-2008, 02:57 PM
2005 Ford F-150
Vehicle: 2005 Ford F150, 2008 Ford Taurus X
That doesn't look good.
Lifechurch.tv
Quote:
Originally Posted by ian51279 View Post
Those of you who think you know it all are very annoying to those of us who do.
Quote:
Originally Posted by Albert Einstein
The difference between genius and stupidity is that genius has its limits.
Old 12-30-2008, 04:33 PM
Vehicle: 2007 Ford F-150 FX4
I resently just removed all my plugs from my 3v 5.4 it has 61,000km's all came out perfectly couln't have been happier! I cleaned all the carbon deposits off applied some dielectric grease on the COPS along with anti seize on the shaft of the plug, and just a touch on the threads and I mean just a touch!
I will most likey replace them in the spring with the Autolites from Ford, oh by the way do any parts stores sell these cheaper then the dealer?
Old 12-30-2008, 04:38 PM
2005 Ford F-150
Vehicle: 2011 Ford F150, 5.0
Autolites are not from Ford. Motorcraft is from Ford and tho they are manufatured by the same company, they are to different specs.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
