broke a plastic air hose insulated in foam
Old 03-28-2007, 03:32 PM
tominos's Avatar
hey guys, new here.
i was working on replacing the plugs and coil packs in my 99' e250 with the 5.4l, and i broke a plastic hose that goes from the intake manifold to the passenger side valve cover. what is this hose called? its wrapped with foam, and doesn't look like it carries anything except air.
i looked, but is there a place where i can look at diagrams to find out what things are? thanks
Old 03-28-2007, 03:42 PM
jbrew's Avatar
The PVC hose - it runs from the pvc to the back of the manifold
Old 03-28-2007, 03:49 PM
tominos's Avatar
cool. thanks for the quick reply. is that a dealer only part or can i get that at autozone or something?
Old 03-28-2007, 03:55 PM
jbrew's Avatar
I would fix it with a piece of rubber hose, but you can try auto- zone ..
take this pic with yuh -
Old 03-28-2007, 03:57 PM
tominos's Avatar
sweet. thanks man.
Old 03-28-2007, 05:39 PM
DDan1967's Avatar
Don't waste your time with Autozone, unless you are just going to use hose to replace the PCV line.
I checked with them when I broke mine and they don't carry and can't get it.
Also the reason the tube has foam insullation on it is to keep water vapor from freezing. This was a recall item on the '97, something about the throttle sticking wide open as I recall.
Doug
Old 03-28-2007, 06:19 PM
jbrew's Avatar
Doug
I didn't know that thanx- I was curious why my 98 never came insulated, like the others seem to be..
Old 03-28-2007, 07:12 PM
Faster150's Avatar
mine came insulated on my 97 but just got get a peice of hose from autozone. i beleive it will take 5/8" and two hose clamps and replace that hose.. ford wants lik 65 bucks for that PCV line its retarded
Old 03-28-2007, 07:32 PM
jbrew's Avatar
I'll bet when I gotta a new motor in late 2000 the frickin guys didn't put my sleeve back on..I think I have something like that on a squat bar in the basement..
Old 03-28-2007, 08:15 PM
Faster150's Avatar
lol is ur sqaut bar that small??? lol
Old 03-28-2007, 08:35 PM
jbrew's Avatar
Yeah , it's bent too
Actually that prolly won't work will it
Unless I cut that foam piece so it closes tighter and then wrapp it with tap - FORGET IT - to much work..
Old 03-28-2007, 09:21 PM
Faster150's Avatar
lol theres no point in putting it on
Old 03-28-2007, 11:31 PM
jbrew's Avatar
Although I did notice that white milky crap feeding into my intake at one point from that line - but that's when it was idleing allot and I kept pulling it in a warm shop from the cold for about a week..So.... That's why that happened I think..
Old 03-28-2007, 11:58 PM
Faster150's Avatar
so u had water in the oil?? oil goes milky like that when water is introduced and heat
Old 03-29-2007, 12:16 AM
jbrew's Avatar
Condensation from running it at idle for long periods of time - from cold to warm climants - like you would get with short trips in the winter. Didn't hurt it..
Quick Reply: broke a plastic air hose insulated in foam
