Help me id these transmisions
Old 04-18-2016, 10:00 AM
Mike04's Avatar
Hi I have a 04 f150 4X4 5.4
I have no reverse in the truck currently and I'm trying to figure out what trans is in the truck so I can run to the junkyard and pick up a used unit
This is the code on the transmission
3L3P 7000 LA FDF2
And this is the code on the transmission I'll be trying to purchase
6L3P 7000 EB FFX0
Is there any transmission experts here that could tell if that transmission will work in my truck?
Old 04-20-2016, 07:57 AM
Darrin Burch's Avatar
The one you are looking at is from an 06 5.4l 4x4
Should be a direct swap.
D
Old 05-03-2016, 04:58 PM
Bsmith1380's Avatar
I have a 1998 F 150 2 wheel drive with the 4.6 V8 what transmission do I have the tag on the passenger side does not tell me enough information
Old 05-03-2016, 05:22 PM
glc is online now
Most likely a 4R70W. Look on the door jamb sticker, a 4R70W is code "U".
Old 05-04-2016, 08:18 AM
That transmission should actually have come out of a 99 4.6L 2wd truck.
Regardless, that's a 4R70W.
D
Old 05-05-2016, 08:06 AM
Bsmith1380's Avatar
Thanks bub
Old 09-07-2022, 07:53 AM
Maikel's Avatar
Hey guys, im new here and also new when it comes to working with ford vehicles.
im from south america and we usually only get ford rangers but a relative bought 2 ford f150 5.4l v8 and both with transmission issues.
The transmissions are equal but i cant identify them completely, i asume they are the 4r75e but im hoping you guys could help me out with that.
I just read about the door sticker so thats one thing ill still have to check.
The code on the passenger side of the trany states
3L3P 7000 LA FDF2
PKF-DF2
Please and thank you for any help.
-Maikel.
Old 09-07-2022, 10:19 AM
glc is online now
That's a 2004 4R75E.
The following users liked this post:
Old 09-07-2022, 02:37 PM
Maikel's Avatar
Okey thanks Glc. Any Rebuild kits that are recommended or any that someone should avoid? Im guessing in oe of the 2 trannys the reverse band is broken but ill do a complete rebuild and i was thinking on going with the master rebuild kit from transstar or rebuild kit from Remco. Any ideas if theyre good or not?
Thank you.
-Maikel.
Old 09-07-2022, 02:50 PM
Maikel's Avatar
I just checked the papers and it says 2006 ford f-150 XLT Triton 5.4l. it is imported from the States to Py and it is possible that they modified the documents.
I still believe its a 4r75e, i read somewhere that 2004 and up the 5.4l all had the 4r75e right.
thanks
-Maikel.
Old 09-07-2022, 03:52 PM
glc is online now
Rebuild kits are all the same for 4R70/4R75. I recommend these people, he's a forum member (Darrin Burch) and does top quality work:
https://www.bcawebstore.com/index.ph...oduct_list&c=9
The following 2 users liked this post by glc:
Old 09-07-2022, 05:24 PM
Maikel's Avatar
Again thanks alot.
-Maikel
Old 09-07-2022, 07:10 PM
Ditto on glc's recommendation. Darrin run a very reputable company.
Quick Reply: Help me id these transmisions
