04 f150 fx4 tranny swap
I have a 2004 f150 fx4, lost overdrive, so i went with the rebuilt replacement. When i got the truck back i noticed they installed a 4r70w. I had to take the truck back to them because the transmission was slipping and slamming into 2nd and 3rd gears. It didnt happen every time, but it happened often. So i guess my question is; was the 4r70w the right thing to do? Or should it have been a 4r75e?
Thank you.
Thank you.
Well, I just talked with the transmission shop. He said the 70w is what was in the truck already? They did not have any rebuilt in stock so they rebuilt mine. Now they are taking it back out to address a pressure problem. Hopefully better luck this time around.
Nah, they know if it's a pressure problem or not. There is no way in the world they would pull a transmission out of the vehicle to check that. It only takes minutes to put on a gauge and check pressures with the transmission in a running vehicle. It takes hours to pull the transmission and then you definitely can't check any pressures without putting it back into the truck or onto a transmission dyno. A transmission dyno isn't going to give you what it's doing in the vehicle and most places don't have one.
They know whats up. Either that or you need to go get your truck.
D
D
