Happend again 4R75 Transmission
So I last year after my transmission was not shifting right I took it to a Trans shop and they did a good job, as far as I could tell. they guy told me it was a Check ball that is commonly worn out on these transmission, and it would need to be replaced. he said it basicly wasn't moving when it needed to to shift properly, thats why it was sticking after it shifted and having trouble shifting. when I got the invoice it shows a transmission service charge, filter, and fluid, but it has a "valve body" on there as well, with a check ball under all that. i didn't think anything of it because the truck worked perfect again. Until... I took another cross country trip and pull some extra weight, over the ford recommended tow speed. Sorry, I like to get where I'm going in a hurry.... So yes I overheated the transmission again. and im back to square one with the way my truck is shifting. Now, I don't want to fork out a few hundos again to have this issue fixed, i've learned my lesson, not to drive fast with a heavy load. so I need some help figuring out what was replaced when this shop did the work. can anyone help me out with parts, and part numbers, and instructions on what and how these parts can be replaced? I am very mechanically savvy. having been a heavy equipment mechanic for 8 years. Im just not too familiar with auto trans in a regular pickup. I have a couple of exploded views of the transmission, just no instructions on the easiest way to pull it out and replace these parts or the part # or names of these valve body and check ball. any help from an experienced ford guy would great be appreciated.
2004 Ford F150 FX4
2004 Ford F150 FX4
You have no way of knowing with any certainty whether this is caused by the exact same thing or not. A qualified transmission tech needs to open it up and start investigating. If you have seriously overheated it twice now, I'd be looking at a full rebuild.
Would you, as a heavy equipment mechanic, think a motorcycle mechanic could troubleshoot and fix an internal issue in a large diesel?
Theoretically, a transmission should last the life of the truck, but we all know that doesn't always happen. Abuse drastically shortens the life. If it has 100k on it with that kind of abuse, it's probably time for a rebuild.
If you think you can rebuild it, get yourself a manual, pull it out, and start tearing it apart and see where you are at.
I have always wondered if this is a materials issue or a problem with something that was put into the fluid.
D
