Alignment shop seems to be very wrong, please help
Good evening,
I took my truck in for an alignment last week at Goodyear. After about an hour they called and said to get my caster alignment right they'd need to install a bolt kit and it would run $123 installed. Looking at what they installed it didn't seem they installed the notched portion in the hole they were supposed to but they did say alignment was way off so I assumed that had to be that way. Driving the truck home I noticed I and to have the steering wheel turned quite a bit to the right to keep it straight in the road or it'd drive quickly to the left. I took the truck back to the shop and they made more changes. Now I have to have my steering wheel turned slightly to the left and it pulls to the right when I left go enough that it changes lanes on the interstate. Looking at the bolt they installed they had moved it and put it in the proper notch. I'm planning on a third trip back but at this point I'm concerned they don't have the knowledge to get it right. I'm including photos here of the alignment specs that I took when they had the paperwork. I don't understand these but do notice they are quite far off for it to have supposedly been right the first time. At this point I've lost a lot of time dropping it off and getting rides to and back from work by friends.
Thanks for any insight you all can provide!
-David
This is the data after the first alignment.
This is the new bolt installation after the first alignment.
This is how my steering wheel looked when driving straight after the first alignment.
This is the data after the second alignment.
This is the bolt position after the second alignment. I'm wondering if I even needed it in the first place.
This is how my steering wheel looks when driving straight after the second alignment.
-David
indont trust the chain shops at all. I had issues myself with Monroe recently. Took them 3 tries. It's within spec, but my alignment guy (who was closed when I needed one) said he could get it much better.
Steer ahead should be reading 0.00° not sure what they're doing wrong.
Are they telling you something is worn out or wrong with your truck?
Is your truck stock height??
Generally speaking, the alignment cam kit is only needed on vehicles with altered suspension (leveled, lifted, lowered, etc). Even then it is not a 100% required but does make doing the alignment easier. On a stock height truck, unless something is severely wrong with your front suspension, it shouldn't be needed at all.
Said camber was so far couldn't align without bolts initially
This is why I also don't go to chain shops. Certain things belong to hometown shops or dealerships. Sorry to hear of this misfortune. When I had my last alignment dealer said my camber bolts kept seizing and needed replaced so I went ahead and did them. My truck kept losing alignment slowly over a year's time. It has been good recently I suppose, I don't drive it that often now, and I changed my tie rods last spring and I did a DIY alignment in my garage with measurements and patience. Drives straight and the wheel is centered. I do plan to have it checked by the dealer before winter.
