Going to do a 6+3 lift. Does one have to be done before the other?
Thanks all for the past help on my other questions.
I'm going to end up doing a 6" suspension lift with a 3" body lift on my '03 Screw FX4.
Does it matter if the BL is installed before the suspension lift or vice versa? I was thinking of doing the BL first since it's cheaper and getting the suspension lift a few weeks later. Is it more difficult or easier one before the other? I plan on installing myself to learn how to do it and because I like to tinker.
Thanks much!
Thanks much!
Thanks much!
Thanks much!
If you do the suspension lift first, it will give you little more room to work the BL in. Other than that though, I don't think it really matters. I did the BL first, then the custom exhaust so when I do my suspension lift, everything will be nice and neat. Many members stack lifts on here with no problems.
If you plan on doingh the install BL yourself, I have detailed pics with captions and descriptions in my gallery, so you know what you are in for. Good luck and be sure to post some pics when it's all completed.
I don't think it really matters. I might be in the same boat as you, I have a BL right now on my 03 SCrew, thinking about adding a suspension lift.
I dont think it really matters which one you put on first, I did the body lift first on mine but like some others have said if you do the suspension lift first you will have more room to work but it will be futher to jack the body up off the frame, either way you decide to do it will work, good luck with the installs
