King shocks install
King shocks install
I have recently purchased king coilover and rear shocks for my f150 king ranch 4x4 the rear are perfect the front however are not bolting up correctly (they hit my axle) i have measured and tried to make work, i can not seem to get clearence they hit at bottom of shock housing and last coil. I could use a larger spacer on bottom but from all figures i shouldnt have to anyone know whats up anyone have these on there truck? Any help would be appreciated! P.s. I have factory 20" wheels does this make any difference.
F150 k.r. 4x4
edge evo.
King shocks
banks cold air kit
tornado air managment
F150 k.r. 4x4
edge evo.
King shocks
banks cold air kit
By spacer i mean above the bottom knuckle or rod end there is a spacer that goes up to the retainer bottom plate for the spring (i wish i could show a picture but i do not have one.) this seems to be not long enough, but by all measurments they are correct. No aftermarket lift and they are the correct shocks for the application i am not in an area to be able to just run them down to a shop. I contacted king shocks and the measurements are to spec they are also confused "i think" p.s. They are a extreem help on this though!! I just can not figure it out. Shaft measures 3.5" overall shock length is 23" top plate tp middle rod eye. If i put in a longer shaft spacer what will that do to my spring?? Can it even work??
Can you please get a picture of it? I don't think any of us have any idea what's wrong. I had a problem with my Kings but it wasn't something wrong with them. Just step back and figure out how to make it work or what you're doing wrong. If they are the right shocks than it's something you're doing wrong. Trust me, we've all been there, but post up a picture and I can help you.
Thanx for your time everyone. I will try to get a picture of the shock on the truck (i had a ford dealer also try and he had the same result.) hhhmmm i hate to have them not work. If nothing else it is nice to have dedicated/ inteligent peaple out there willing to try, i will post pictures later tomorrow. Thanx again all!
Yes the shock is long enough no problem there. It is the circumference of the coil and retaniner plate. It is hitting the axle shaft. But everyone, king and others who have it installed on theres says its ok. My spring diamiter is same 3" 16600. I will post pictures tuesday. As they say a picture is worth a thousand words. Or 2100 in this case.
Sorry man, I don't get it.
I found this install for reference. Hope this helps.
http://www.off-roadweb.com/tech/0605.../photo_01.html
Davespeed your the man, thats what i needed i have been everywhere trying to find that. Ok at the bottom where the coil sits on the retainer plate it rubs against the axle as in picture #1,my bottom spacer after the rodeye piece is 3.5" which is spec for new from king. Thats why i thought if i got a larger spacer it would rise the coil up and out of the way! But why mine is different is puzzling,i bought the truck new never wrecked or tweaked! I am seeing in the picture it is also very close to rubbing. I will try again thanx everyone for your help!!
Yep, i have measured and called and measured now you see my delema. Absolutily correct spec of spring size is :3" /16600/13" long. I dont know what else to say i will try again but may soon resort to another brand. Which is a drag becouse i run kings on my 1972 fj40 v-8 pro-jection and special setup on my cobra both work flawlessly. Thanx all.
