Truck wanders while driving.
I have a 1994 F-150 351 W 4x4 XLT. When I drive it wanders from side to side like something is lose in the steering. I have replaced the ball joints, radius arm bushings, tie-rods are tight. When stopped and turning the wheel you can hear a creaking noise. It started doing this shortly after taking the body lift off. Any help will be appreciated. Thanks!
I'm almost sure this is correct but the 4x4 has a wider track at the front end than the rear axle. This makes the truck prone to wandering. If you have larger than normal tires you'll have to live with it or you can have the toe end set in more but it's going to wear the tires on the outside.
