Keyless Entry reset... please help!
I just got my new (to me) truck, a 2004 F-150 Supercrew Lariat.
It has 46,000 miles on it so it's no longer under warranty.
Heres my problem. The Keyless entry keypad on the drivers door is not working with the code the dealership gave me. I know the keypad works because when I hit "7-8" and "9-0" it locks the doors.
I've read the owners manual and followed the directions that it gave step by step.
So at this point I'm assuming the dealership gave me the wrong card and code for it.
What can I do? Is there anyay to set a new code without the factory one or is the code printed somewhere on the inside of the vehicle.
This is one of the features I was really excited about and now it's not working
PS I can't go back to the dealership because they are about 7 1/2 hours away from me.
Let me know too!
If someone has an answer for this please let me know too. Just got an 02 screw same thing. chadandtobie@eatel.net
Thanks!
Thanks!
There's some posts here about were to find the code for Keyless entry keypad,on the 02 it's may be under dash drivers side stamped on the mod.The 04 they may have to hook the computer to get it out.In the book it's about putting in a second code but have too run the factory code before you can set up the second code.What I have seen on the posts they move the mod around each year in a new spot.But for a few bucks ($70)a dealer can get it out for you. Keyless entry keypad saved me a few times that's why I went with a FORD.Why do they keep the code card when they get a new vel,we may never know why.
HARDCOREHEHAW (never thought I would be typing that!)
anyway I had the same problem with my 2005 F-150
there is Only 2 options for you.
1. go to the dealer and have them get the code from your VSM (Vehicle security Module) or
2.Locate the VSM BEHIND the rear seat back on the drivers side the code is on a white sticker on the front of it.
its a pain in the A** to get to it but it's the only do it yourself solution.
Ben
Ben
HARDCOREHEHAW,
their are only two ways to get the code...
(1) You have to either go to the dealer so they can read the code by hooking up to the computer at the dealer
(2) remove the UPPER part of the back seat and the VSM is mounted behind that on the driver side, its a black box with two plugs going to it... the code will be on it in the form of a sticker.....you can search on here for info on removing the back seat.... and yes it can be a bear to unlock....
