Rustoleum Spray on Bed Liner/ Rockers and Bumpers Done!
#153
Anyoneknow how well herculiner works? Im thinking about tearing my bed liner out this week and putting that in. And im wanting to clean up underneath and paint everything black. Should i just use regular flat black paint, and heat paint on the stuff that gets hot?
#155
#156
These are taken from my phone. I'm going to end up painting a lot more stuff on my fourwheeler with this stuff. It was scratched up like none other before this so to me it looks 20x better. I just sanded it down and put 3 coats of self-adhesion primer on and then sanded that and put 2 coats of this stuff on. Makes it look brand new.
#158
Shouldnt at all if you put some clear coat on it.
#161
Two questions;
1. I plan on using this stuff on my frame and wheel wells. I was going to use some white paint over the bed liner stuff in the wheel wheels so it has the factory look. How well will this stuff hold with rocks being thrown at it? And how well will the white paint stick the the bed liner while rocks are being thrown at it?
2. I might even do my bed with this stuff. I rarely put anything in there. Maybe a few boxes once and a while. I also have a tonneau cover. Would this be a bad idea?
Thanks.
Thanks.
#163
This stuff rocks
I did all my badges and the rear Ford Oval. Looks great!!
I also sprayed the grill surround on my truck to give it the off/flat black look. The key is prep. Make sure you clean it very well and even rough it up a bit with sandpaper. Prep is key and I couldnt do it without this thread. Thanks!!
#164
Couple of crappy cellphone pics...
But I am very pleased with the outcome....
I just did the "grill surround" as it was too shiny and did not flow with the look Im going for....
I will post some better pictures (with an actual camera) if anyone is interested....
